FBaggshorses 3 #1 Posted May 20, 2021 In an attempt to remove the fuel line from the petcock on the bottom of my gas tank on a C-120 I inadvertently pulled the entire grommet out of the bottom of the tank spewing gas everywhere. Yes, in hindsight I should've emptied the tank but figured closing the petcock would be suffice... Wrong! What a mess.. had gasoline everywhere. Anyhow my question is: Is it necessary to use a sealant on the grommet prior to re-installing it back into the bottom of the gas tank? Oh and advise very appreciated thanks in advance. Share this post Link to post Share on other sites
bc.gold 3,403 #2 Posted May 20, 2021 (edited) No sealant required., Install the grommet first then the petcock, liquid soap helps. Edited May 20, 2021 by bc.gold 5 Share this post Link to post Share on other sites
roadapples 6,983 #3 Posted May 20, 2021 Don't use a grommet over. You can get a new grommet and shut off for 10 to 15 dollars... 7 Share this post Link to post Share on other sites
ebinmaine 70,291 #5 Posted May 20, 2021 4 hours ago, roadapples said: Don't use a grommet over. Agreed. The rubber is very likely hardened and formed to the position it used to be in. 8 Share this post Link to post Share on other sites
ranger 1,773 #6 Posted May 20, 2021 4 hours ago, roadapples said: Don't use a grommet over. You can get a new grommet and shut off for 10 to 15 dollars... Yes to this. One thing, did the grommet come out in one piece, or did it break, there may still be part of it inside the tank. I have always found gas a good lube for rubber suspension bushes etc, it evaporates quickly, grease doesn’t. 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 27,127 #7 Posted May 20, 2021 Vendor on this site - wheelhorsepartsandmore.com sells them. I just installed one few days ago. Easy. 3 2 Share this post Link to post Share on other sites
Maxwell-8 4,366 #8 Posted May 20, 2021 Like Dino mentioned in my topic, always use a lubricant when installing.It's easier to install but mainly easier on the grommet. 2 Share this post Link to post Share on other sites
Achto 28,545 #9 Posted May 20, 2021 Check your local hardware or small engine shop. There is a good chance that they have those tank grommets on hand. They were used by many company's. 3 Share this post Link to post Share on other sites
The Tuul Crib 7,338 #10 Posted May 20, 2021 I use wd 40 . What little you use will mix in with gas! T😎 2 Share this post Link to post Share on other sites
305 380 #11 Posted May 20, 2021 Primeline part # 7-07461 available from Oreilly or Napa for about 3 bucks 3 Share this post Link to post Share on other sites
Jeff-C175 7,203 #12 Posted May 20, 2021 1 hour ago, Achto said: Check your local hardware or small engine shop. There is a good chance that they have those tank grommets on hand. They were used by many company's. 1 Share this post Link to post Share on other sites
peter lena 9,051 #13 Posted May 20, 2021 @FBaggshorses, use a DIELECTRIC GREASE ON THAT GROMET , made for rubber to metal use , also try to get a straight installation push into the tank hole , for easiest fit , pete 2 1 Share this post Link to post Share on other sites
johnnymag3 2,559 #14 Posted May 20, 2021 What Pete said.... perfect for install, and preservation of exposed rubber !!! 1 Share this post Link to post Share on other sites
clueless 3,105 #15 Posted May 20, 2021 (edited) If it's the original grommet that make it at least 44 years old, buy a new one with the valve, cheap fix, might make it another 40+years. Since the tank is empty remove it, simple, and rinse it out with a little soap and warm water, lay it upside down in the sun for awhile, with both holes open it won't take long to dry and the sun will help soften up the tank. Take the valve and put a little lubricant on it, preferably petroleum based, I use a little 3in1 oil, I use the s**t on everything #OLDSCHOOL, now push the valve half way into the grommet now put a small amount of the lubricant on the end of the grommet. Start the grommet in to the tank, once it's started push the valve in and it all slides in, easy peesy. Old Wheel horse mechanic show me this, works every time. Edited May 21, 2021 by clueless 5 Share this post Link to post Share on other sites
FBaggshorses 3 #16 Posted May 21, 2021 Wow ok, alot of good knowledge there .Thanks alot greatly appreciated Share this post Link to post Share on other sites
bc.gold 3,403 #17 Posted May 21, 2021 On 5/20/2021 at 9:10 AM, clueless said: If it's the original grommet that make it at least 44 years old, buy a new one with the valve, cheap fix, might make it another 40+years. Since the tank is empty remove it, simple, and rinse it out with a little soap and warm water, lay it upside down in the sun for awhile, with both holes open it won't take long to dry and the sun will help soften up the tank. Take the valve and put a little lubricant on it, preferably petroleum based, I use a little 3in1 oil, I use the s**t on everything #OLDSCHOOL, now push the valve half way into the grommet now put a small amount of the lubricant on the end of the grommet. Start the grommet in to the tank, once it's started push the valve in and it all slides in, easy peesy. Old Wheel horse mechanic show me this, works every time. Every abandoned farm house had at least one tin. 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #18 Posted May 21, 2021 44 minutes ago, bc.gold said: Every abandoned farm house had at least one tin. I must live in an abandoned farm house then! Maybe 3 or 4 ! I've even got a couple cans of Singer Sewing Machine Oil! 1 Share this post Link to post Share on other sites
