Tyler71
Wheel keeps falling off spindle
Tyler71
Hey guys looking for a way to fix my 702
the front wheel keep slowing sliding off the spindle and i slide them back on and put the clips on and will be good for a while them it will do it again looking for advise to fix it
Pullstart
Hi Tyler,  you might try replacing the C-clips, but I wonder if your spindles are worn so the grooves aren’t square?  If you can drill and tap the end of the spindles, a 3/8-16 x 3/4” long bolt and a good washer will help remedy this issue.
  • Excellent 2
pfrederi
Or drill through the axles and use a cotter pin.  WH used E clips cotter pins and bolts over the years.  If you use the bolt method use a self locking bolt...especially on the left side...
Maxwell-8
All the 300, 400 and 500 series used this methode and I believe my raider as well. Probably more  models.
ranger
If you stay with the “E” clip, or Circlip method, fit new clips, but check the clips before you fit them because they are most probably made by a “Stamping” type process and will have one side/edge sharp, and the other slightly rounded. Make sure the “Sharp” side goes to the outside, and the “Rounded” side faces the wheel. Also, as previously mentioned, make sure the groove in the axle isn’t worn. If the groove is worn, you could possibly try “Cleaning” the groove with a hacksaw blade, and deepening it slightly. You should then be able to find a smaller clip, (metric?), which fits.
Doug.
Edited by ranger
  • Like 5
Tyler71
ok thanks guys ill see if i can drill it out.... i like that idea the best with a cotter pin
seuadr
Doug.
I don't think i've ever thought about this - that is great info/advice!
