The Tuul Crib 7,336 #1 Posted May 19, 2021 I am just wondering why the B chose this narrow hoe handle to chew a hole! Maybe im not usin my hoe enough! 1 3 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,296 #2 Posted May 19, 2021 Same reason that I had to replace all the trim boards on my small from porch. Because it was there. Those suckers did a number on the boards luckily they didn't start on any of the 2 x lumber.. 1 Share this post Link to post Share on other sites
lynnmor 7,302 #3 Posted May 19, 2021 I guess the bee is like a chicken that crosses the road. (To get to the other side.) 1 3 Share this post Link to post Share on other sites
Pullstart 62,803 #4 Posted May 19, 2021 Depending on the height of that hole, nice hanger hole! 1 Share this post Link to post Share on other sites
stevasaurus 22,711 #5 Posted May 19, 2021 A sawdust and white glue mixture will make that look like it was never there. 1 1 Share this post Link to post Share on other sites
formariz 11,987 #6 Posted May 19, 2021 Carpenter bees are interesting creatures. I wish sometimes they came in different sizes since they drill a real nice hole. They are fond of pine specially if it is not finished or treated in some way. They usually stay away from hardwoods. Giving the pine an application of a mixture of linseed oil and turpentine ( heavy on the turpentine) keeps them away from it most of the times. They may just start nibbling on it until they detect the turpentine. 18 hours ago, The Tuul Crib said: Maybe im not usin my hoe enough! That is for sure. It takes them a while to drill that hole. 17 hours ago, lynnmor said: I guess the bee is like a chicken that crosses the road. (To get to the other side.) They drill in about 1/2" and then make a perfect 90 degree turn for about 1-1/2". If board is only 3/4" many times they go through. If you have them in an outside shed clad with thin boards, place an insecticide "bomb" inside. Stuff will penetrate through the thin wood left and it will kill them all. You will find them all over the floor inside and outside along with some other insects you may have not known about. 1 Share this post Link to post Share on other sites
Jeff-C175 7,199 #7 Posted May 19, 2021 I've used a variety of stuff to get rid of them, eventually tearing out the fascia boards and replacing with pressure treated and cladding with aluminum. 1. Suck em up with my shop vac and a long wand. Wave the wand around and they'll get curious to investigate. Fly too close and WHOOOSH! they're gone. 2. Tennis Racket. My neighbors already think I'm crazy, why not add fuel to the fire? Must look a hoot when I'm out there swatting at stuff they can't see. 3. Brake or Carb cleaner into the holes. NOT recommended! Too flammable! 4. Wait for them to go in the hole and plug it with plastic wood. The fumes from the PW will kill them. 1 Share this post Link to post Share on other sites
Razorback 1,035 #8 Posted May 19, 2021 I remember long ago sitting outside my cousin's dairy barn watching carpenter bees coming and going. We went to the shop, got the can of WD-40 that had a trigger sprayer on it, set it for a stream...... Bees would come out to the edge of the hole, buzz their wings, and take off. While they were there buzzing their wings, we hit them with a bit of WD-40..... Dropped them like a rock. Share this post Link to post Share on other sites
The Tuul Crib 7,336 #9 Posted May 20, 2021 4 hours ago, Jeff-C175 said: I've used a variety of stuff to get rid of them, eventually tearing out the fascia boards and replacing with pressure treated and cladding with aluminum. 1. Suck em up with my shop vac and a long wand. Wave the wand around and they'll get curious to investigate. Fly too close and WHOOOSH! they're gone. 2. Tennis Racket. My neighbors already think I'm crazy, why not add fuel to the fire? Must look a hoot when I'm out there swatting at stuff they can't see. 3. Brake or Carb cleaner into the holes. NOT recommended! Too flammable! 4. Wait for them to go in the hole and plug it with plastic wood. The fumes from the PW will kill them. Share this post Link to post Share on other sites
The Tuul Crib 7,336 #10 Posted May 20, 2021 Oops! I pushed the wrong button. They make traps for this and I'm thinking all I need is a box or two of mason jars and make the traps! Share this post Link to post Share on other sites
formariz 11,987 #11 Posted May 20, 2021 1 hour ago, The Tuul Crib said: Oops! I pushed the wrong button. They make traps for this and I'm thinking all I need is a box or two of mason jars and make the traps! Yes the traps are pretty effective and look pretty cool. Share this post Link to post Share on other sites
Stormin 9,981 #12 Posted May 20, 2021 I make traps for wasps etc from a used unwashed jam jar. Half fill with water. Cheap and efficient. Share this post Link to post Share on other sites
Wheel Horse 3D 3,791 #13 Posted May 20, 2021 For carpenter wasps(actually a wasp) or what we around here call a wood borer, or borer bee(looks like a bumble bee) we stuff a paper bag with news paper and hang 'em around the deck. They seem to interpret the bag as a hornet's nest and stay clear of the area.(Reminds me i need to get those put up!) 1 Share this post Link to post Share on other sites
Jeff-C175 7,199 #14 Posted May 20, 2021 1 hour ago, Wheel Horse 3D said: stuff a paper bag with news paper Couldn't you 3D print a hornet's nest? Maybe even some hornets? Suspend them on dangly wires so it looks like they're buzzing around it. I used to wear a "Hillbilly Toothpick" on a chain around my neck. It was supposed to prevent alien robots from stealing my luggage. DON'T LAUGH! IT WORKS! Alien robots have NEVER stolen my luggage! 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,791 #15 Posted May 20, 2021 (edited) I actually had an abandoned hornest's nest but gave it away. I don't think ABS plastic replica would deter the borers any. lol I believe its the paper they "see"(sense,smell, whatever). A hornet's nest is essentially paper. I guess I could get my paper mache goin, but the bags work, an ya'll know I'm lazy, I have robots doin all the other work for me! Edited May 20, 2021 by Wheel Horse 3D Share this post Link to post Share on other sites
Jeff-C175 7,199 #16 Posted May 20, 2021 5 minutes ago, Wheel Horse 3D said: my paper mache goin, but the bags work When I first read that, my brainiac saw "groin". Share this post Link to post Share on other sites
Wheel Horse 3D 3,791 #17 Posted May 20, 2021 2 minutes ago, Jeff-C175 said: When I first read that, my brainiac saw "groin". Dear lord! please bless Jeffs brain. 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,791 #18 Posted May 20, 2021 (edited) AND tie in the robots too... ONE SIMPLE LETTER MAKES ALL THE DIFFERENCE! Edited May 20, 2021 by Wheel Horse 3D Share this post Link to post Share on other sites
Wheel Horse 3D 3,791 #19 Posted May 20, 2021 And that Ladies and Gentlemen is why CONTEXT MATTERS! Share this post Link to post Share on other sites
Jeff-C175 7,199 #20 Posted May 20, 2021 14 minutes ago, Wheel Horse 3D said: AND tie in the robots too... I did catch that! Not much gets past me! Share this post Link to post Share on other sites
