Jonnyrocket132
wheel horse B 80
c-series don
My guess is that the hood is not grounded, I’d take a wire from the negative terminal on the battery to the bolts that hold the headlight bezel in place. If that works then you have a bad connection at the hood hinge.
Jonnyrocket132
that is what I thought to because there wasn't a grounding wire for the lights but after I installed one it still didn't work. so this one has me stumped again.:eusa-think:
Edited by Jonnyrocket132
Jonnyrocket132
I was about to take the engine apart and fix what I thought was the timing was a little off but I fired it up just to be sure and it idled really well and when I revved it it didn't even hesitate or nothing. so it just started running better all of a sudden. also I got the headlights to work and the tail light works to. Now the only thing left to do is get an inner tube for the back right tire.
Jonnyrocket132
does anyone know where I can find a rear right side tire and rim for really cheap for this B 80?
Jonnyrocket132
I finally found an inner tube so know she is ready to mow again
Jonnyrocket132
and I think some of you guys have seen this one at the show since the previous owner brought it once.
Jonnyrocket132
unfortunately after I tested the pto today with the mower deck the engine started knocking really bad and I only started mowing for a few minutes.
Jonnyrocket132
Update on the B 80,
I bought another engine rebuild kit since it did end up throwing another newish rod and it survived it so I am gonna try to rebuild it again.
Jonnyrocket132
I installed the new oem rod and new gaskets from the rebuild kit and it runs even better than it did before
Moparfanforever
Glad you got it running good again !!
Those little 8HP engines are hard to beat !!
:thumbs:
Jonnyrocket132
Yeah this one has shown me that it doesn't want to die yet after three different rods letting go and this is the fourth and hopefully the last one that will last
Jonnyrocket132
I unfortunately need to get rid of this B 80 if anyone wants it it's for sail for $200
