FrankinWNY 12 #1 Posted May 14, 2021 How and where do you drain the oil from the pump? Share this post Link to post Share on other sites
stevasaurus 23,072 #2 Posted May 14, 2021 I'm not sure on the Eatons, but on the Wheel Horse transaxles with the Sunstrand pumps, the transaxle is the reservoir for the pump hydraulic oil and it drains from the bottom of the transaxle. Do you have the breakdown for your horse, it should show you if there is a drain plug on the transaxle??? We also have an Eaton Manual in the "Manual" Section under transmissions. Hope that helps. Share this post Link to post Share on other sites
shallowwatersailor 3,214 #3 Posted May 14, 2021 (edited) Is it contaminated or are you just changing it to change it? The easiest method is to use a turkey baster to remove the oil but you may only get 25% that way. But there is a small allen head screw below the transmission housing (not the transaxle as that is 10W-30 motor oil) that can be used for draining the transmission oil. It may be difficult to see. Edited May 14, 2021 by shallowwatersailor 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,246 #4 Posted May 14, 2021 Is this one for your application? Click on the picture in the link Page 9 Fig.12 shows the drain for the pump and the transaxle. Share this post Link to post Share on other sites
JoeM 7,935 #5 Posted May 14, 2021 There is an o-ring plug under the pump behind the fan. It is not to easy to get to but can be done. I made a wrench but a chisel and a few light taps will loose it and it can be removed with the fingertips. You can see the drain in the first pic it is further in toward the inside of the pump. (it has the most light on it) 2 Share this post Link to post Share on other sites
Maxwell-8 4,366 #6 Posted May 15, 2021 How do you fill the pump back up? Share this post Link to post Share on other sites
JoeM 7,935 #7 Posted May 15, 2021 32 minutes ago, Maxwell-8 said: How do you fill the pump back up? Add through the reservoir on the top. Since the one I was working on had moisture in the oil I left the plug out and poured some through. Replaced the plug and added to the highest level. Ran it at idle and rechecked. It did not hold much and I used 10w-30 oil. 1 Share this post Link to post Share on other sites
shallowwatersailor 3,214 #8 Posted May 15, 2021 I remember doing a lot of research when I had a tractor with an Eaton 7. The closest to the original fluid is 20W oil. Share this post Link to post Share on other sites
Tuneup 1,433 #9 Posted May 18, 2021 I've drained mine twice. The first time, I removed it to clean in there - a grassy and oily mess. You can remove the large bottom plug to get the same drain effect. I did that the second time - quite easy. It's easy to damage, though. There is a rebuilder on, cough!, eBay that says nothing less than Mobil 1 15W-50. I have done so and it's quieter and smoother. Also, fill it at the top of the pump first and hand rotate it in both directions until it is full. It doesn't take much. Add the cleaned reservoir and top it off. The reservoir flow is so slow that you'll risk damage to the pump in letting it fill from the reservoir over time. Well, that's my 516H experience and that little pump is running well in my hilly yard with 14 gallons in the tires. Share this post Link to post Share on other sites
