mort 24 #1 Posted May 12, 2021 How does the forum like the Wheel Horse #7607 Rear Tire Cleats 23 X 850 -12 or equivalents? Is it true that you can not use non-ground engaging attachments only? Why? Thanks, Mort Share this post Link to post Share on other sites
ebinmaine 70,699 #2 Posted May 12, 2021 By cleats we mean chains? Depends on many factors.... Asphalt or concrete or aggregate? Is the grass area soft? Why do you want chains? Share this post Link to post Share on other sites
mort 24 #3 Posted May 13, 2021 All of my information above came from a manual or a Wheel Horse brochure. The 7607 are rear cleat tires. They are not turf tires. I am not wanting to put on chains but just changing tires. Never had cleat tires so not sure how they are on grass (not nice sod). Why does it say you can not use non-ground engaging attachments with these tires? Thanks, Mort Share this post Link to post Share on other sites
DennisThornton 4,771 #4 Posted May 13, 2021 This? or this? Share this post Link to post Share on other sites
ebinmaine 70,699 #6 Posted May 13, 2021 42 minutes ago, mort said: Why does it say you can not use non-ground engaging attachments with these tires? I'm fairly new to the garden tractor game having only owned one for just a few years now but I just have no idea why it would say that.... Share this post Link to post Share on other sites
mort 24 #7 Posted May 13, 2021 That is why I am asking the question before I buy them. I don't see why Wheel Horse would say that in their brochure. They only say it on the 300 series not 400 series Could it be related to the two different rims in the manual 111516 & 110677? Thanks, Mort Share this post Link to post Share on other sites
DennisThornton 4,771 #8 Posted May 13, 2021 I've run chains and I've run ag "cleat" tires year round on mowers with no issue. I've done more damage with turf tires when I hit any wet, damp or otherwise slick grassy areas where the greater traction continues rather than spinning and burning up the grass blades. But to directly answer your question, I have no idea other than perhaps someone chose some bad wording and later rewrote it. Buy ags "cleat" tires if you need more traction in dirt or even if you are mowing and have some of those wet or hilly grass areas. 1 Share this post Link to post Share on other sites
mort 24 #9 Posted May 13, 2021 Sounds good! Thanks, Mort 1 Share this post Link to post Share on other sites
JohnD 145 #10 Posted May 19, 2021 On 5/13/2021 at 11:35 AM, mort said: 111516 & 110677? I was just reading another thread that said 111516 replaced 110677 that replaced... Same rim otherwise. Share this post Link to post Share on other sites
