Ifixoldjunk
Kohler k241 problems
Ifixoldjunk
So I have a parts 310-8 I’ve been trying to get running. My problem is the engine runs for 5 minutes and then starts sputtering and shooting exhaust back out the carb. Any clue what is happening? I’m pretty lost.
SylvanLakeWH
I’d start with a complete fuel system clean from carb to tank. New fuel line and filter. Complete carb clean.
:twocents-twocents:
squonk
You may be having an exhaust valve starting to hang up when it gets hot. Fire out the carb usually means there is still fire in the hole when the intake opens.
Maxwell-8
backfire thru inlet is always to rich, should clean out your carb and check the float and needle!   but rich could also mean no/bad spark.
peter lena
might add in a possible bad condenser , or related spark issue. check out electrical plug in connect areas . corrosion , shorting out , pete
  • Similar Content
    • bigbuck
      By bigbuck
      I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
      please call George at 517-499-5678 for more info.
    • CasualObserver
      By CasualObserver
      Owners manual for the two cylinder snowmobile engines.
      12 pages 1.38MB
      1970 399 Safari snowmobile model 9-0041 - 2-cylinder
      1970 440 Safari snowmobile model 9-0051 - 2-cylinder
      1972 399 15" Safari snowmobile model 9-0042 - 2-cylinder
      1972 399W 22" Safari snowmobile model 9-0310 - 2-cylinder
    • CasualObserver
      By CasualObserver
      Owners manual for the Single cylinder snowmobile engines.
      12 pages 1.33MB
      1970 295 Safari snowmobile model 9-0011 - 1-cylinder
      1970 309 Safari snowmobile model 9-0021 - 1-cylinder
      1970 309W Safari snowmobile model 9-0061 - 1-cylinder
      1970 355 Safari snowmobile model 9-0031 - 1-cylinder
      1972 335 15" Safari snowmobile model 9-0032 - 1-cylinder
    • Jeff-C175
    • Jennifer
      By Jennifer
      Husband wants some advice… lol.  So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running!  The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice???   It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky..  checked the gap and pull again… same thing over and over!  Thanks in advance!
