4wheelsis2toofew 23 #1 Posted May 8, 2021 I have a good working 8 speed Wheel Horse transmission that I would like to try installing into a 6x6 amphibious ATV (Attex) powered by an 11 horse predator motor. The original transaxle is junk, and of a fragile model. A Borg Warner t20 is the normal substitute, but I don't have one of those and I do have a wheel horse 8 speed. I still have not sorted out what exact transmission it is (number of pinions, axle diameter). To adapt it I would have to put a disc for a steering brake on each wheel flange, and replace each wheel with a sprocket. I don't know that I would use the original band break at all. I've got a couple options how to run the input power, either a CV, or centrifugal clutch. I know the Wheel Horse transmission can take the horsepower, but I don't know how well it'll work as a skid steer, using steering brakes. I saw where a gentleman made a six-by-six wheel horse, but I wasn't able to figure out which transmission he used, or whether he modified the transmission itself internally. The end-use for this vehicle is low speed, light-duty, yard stuff, like towing a trailer of lawn clippings, or hauling tools around. I am hoping the experience people on this forum would know if this would work. Share this post Link to post Share on other sites
stevasaurus 22,861 #2 Posted May 8, 2021 I think it will work. If you hold one wheel, the other one turns...you may not want to use a 10 pinion limited slip for this though. If your transmission has 1" axles, then it is a 4 pinion differential and should be fine. If you have 1 1/8" axles you can have either 8 of 10 pinion differentials. I would think you want the 8 pinion. One sure way to find out, the 2 bolt holes on top of the transmission for the fenders...shine a light down one and see if you can see the differential in the other. The 8 pinion has 4 bolts holding the differential together, the 10 pinion has 5 bolts. Share this post Link to post Share on other sites
wallfish 17,079 #3 Posted May 8, 2021 Sounds like a cool project. How about some pictures of the 6x6 so we have an idea what you're working with. I don't see why a manual WH tranny wouldn't work, it should. The 6x6 Ian did was run by 2 hydraulic trans I think. Share this post Link to post Share on other sites
ebinmaine 68,302 #4 Posted May 9, 2021 Agreed. I believe it would be perfectly fine. If in fact you do have a 10 pinion transmission you could either swap transmissions with a member here or remove the spring that makes it limited slip. Sounds like a great project. Love to see pics or better yet start a build thread. Share this post Link to post Share on other sites
stevasaurus 22,861 #5 Posted May 9, 2021 Eric, I'm not sure you should take out that spring. It helps keep those pinions in place. 2 Share this post Link to post Share on other sites
4wheelsis2toofew 23 #6 Posted May 9, 2021 I don't think I have a limited slip. When I turn one wheel, the other one turns the opposite direction. I haven't figured out how many pinions yet. I guess I'll start a build thread. Share this post Link to post Share on other sites
ebinmaine 68,302 #7 Posted May 9, 2021 2 hours ago, stevasaurus said: Eric, I'm not sure you should take out that spring. It helps keep those pinions in place. Ah. Ok. Wasn't aware of that. Share this post Link to post Share on other sites
