wheeliepower
big problem - no spark - wheel horse c-175
wheeliepower
hi,
I have a wheel horse c-175 with a big problem. It has no spark. I parked the tractor 3/4 year ago, everything went well back then.
Now i wanted to start the engine but there is no spark. I've already measured the ignition coil, it's ok.
I also don't know if the carburetor works. the spark plugs don't get wet when I try to start.
I already dismantled and cleaned the carburetor that could be an additional problem everything went great 3/4 year ago
I don't know, does anyone have an idea?
regards from germany
Manfred
I also saw this news about a similar problem
Edited by wheeliepower
953 nut
The two most frequent causes of a loss of spark would be the PTO switch not being in the off position or corrosion on electrical connectors.
To verify that you ignition system is functional you can take a small jumper wire from the battery "+" terminal and connect it to the ignition coil "+" terminal. With this done there should be spark at the plugs.
  • Thanks 2
pfrederi
Spray some carburetor  cleaner into the carb then crank.  If she fires you have a fuel problem.  if no fire the you have to clean the points and make sure you have 12volts at the coil.
wheeliepower
To verify that you ignition system is functional you can take a small jumper wire from the battery "+" terminal and connect it to the ignition coil "+" terminal. With this done there should be spark at the plugs  =>  that i did - no start engine
wheeliepower
I don't found a translate for this part => PTO switch not being in the off position
gwest_ca
Pto = power take off.
Don't know your tractor model number so don't know which switch you have.
Click on the picture in the link for more
Garry
pacer
Wait -- if you/he jumped from + battery to + on coil and still has no spark then its an ignition problem - coil, points, cond, etc.
If this C175 has the KT17 twin, and I think it does, then its likely the coil - for some reason the KT17's like to eat coils.
wheeliepower
yes, it is a kohler kt-17 twin, model one
no spark if I connect the + battery withe the + from the coil with a cable directly
I have a check stick with a lamp, which I also have connected too between one spark plug and the spark cable, but there is no light too
surprising, when I used it 3/4 year ago, everything was still working. now I wanted to mow a meadow, nothing works anymore
Unfortunately in Germany wheel horse are very rare and I can't just try a part from a neighbor
I have to see if I still have an ignition coil to test
I have measured the resistances of the coil, they are OK (primary and secondary)
<<< sorry for my bad english, only my friend GOOGLE help me to translate  ;-) >>>
pacer
Manfred, you are doing OK with the translating...
The coil here in the states is readily available on the ebay with reasonable prices - $30-40. One of those sellers will probably offer overseas shipping, Check it out - Just put "Kohler KT17 Ignition coil kit " in search.
Edited by pacer
wheeliepower
us state to expensive (taxes + shipping)
I now have bought this  => https://www.ebay.de/itm/353445748276?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
I hope this works too
but why the coil, both windings are ok (even measured resistance)?
and the Pto = power take off,  I think,I don't have any more this switch
83 / 5000
Übersetzungsergebnisse
pfrederi
Have you cleaned your points??  Connect your test light to good ground and touch the other end to the small negative terminal on the coil.  When you crank the engine the light should flash on and off.  If it doesn't clean and reset the gap on your points....018"
Edited by pfrederi
wheeliepower
yes, I cleaned
If I clip on the test lamp (as you wrote ) and try to start the engine, the light stays on forever (see pic)
what do you mean with =>    "...........If it doesn't clean and reset the gap on your points"
Jeff-C175
If you are actually connected to the NEGATIVE terminal of the coil, which is the same one that the points are connected to, when the points CLOSE the light MUST go out.
What this means is that your points are never closing if the light stays lit all the time.
Could be:
Points still dirty
Improper adjustment
Broken wire or bad connection from points to coil
You don't have to crank the starter for this test, just turn the key to " ON " and turn the flywheel by hand.
Edited by Jeff-C175
wheeliepower
so
I turn off the spark plugs, then I is easier to turn the flywheel from hand
I connected the lamp, I turn the key to "on"
the lamp shines
I turn the flywheel several turns but the lamp always shines
pfrederi
Take the cover off the points. Make sure they open and close as you turn the engine over.  Use a small file to clean them or some clean paper.  Gap should be .018 inches.
Jeff-C175
2 minutes ago, wheeliepower said:
so
the lamp shines
Könnte sein:
Punkte noch schmutzig
Unsachgemäße Einstellung
Drahtbruch oder schlechte Verbindung von den Punkten zur Spule
Jeff-C175
I believe should be 0.020 ?  Not much difference of course.
elcamino/wheelhorse
@Tractorhead Can you help @wheeliepowerwith his problem , not sure how far away he is from your location.
pfrederi
You are correct  however when i set the points with a timing light they usually seem to be a tad tighter than the .020 .. at least  on some engines...could be worn plungers..
Edited by pfrederi
wheeliepower
Engine runs :happy-bouncyyellow:
the arrow shows a point of contact where a piece of metal was pinched
no idea where does that part come from
no matter, wheelie is running
now adjust the carburetor tomorrow, I also suspected and dismantled completely
many thanks all the people here, who tried with me to solve the problem
manfred
  • Excellent 2
Tractorhead
Hallo Manfred, habe leider erst jetzt Nachricht bekommen zu Deinem Problem.
Aber schön dass er wieder läuft.👍
Zuerst mal ein herzliches  :text-welcomeconfetti: to :rs: von mir.
Hast ja ein schickes Maschinchen.
Die Jungs meinten, daß Du deine Unterbrecherkontakte mal reinigen und einstellen solltest.
Btw. Bei längeren Standzeiten empfiehlt es sich, vorher den Vergaser leerlaufen zu lassen, damit er nicht zusetzt.
Beim Sprit solltest Du ab und zu mal einen Blei ersatz Zusatz verwenden,
denn unser Benzin hier in Deutschland ist immer mit mind.5% Ethanol versetzt.
Das mögen diese alten Motoren nicht unbedingt gern.
als weiteren Tipp
Tausche die Spritleitungen aus, denn die originalen lösen sich durch das ethanol im Benzin langsam auf.
Diese kleinen brösel schwemmt es Dir dann in den Vergaser und setzt den zu.
grüsse aus Bayern
Edit: (btw 0.020 meint 0,45-0,5 mm Unterbrecherabstand)
solltest Du Hilfestellung zum einstellen benötigen, melde Dich einfach
end edit:
Edited by Tractorhead
wheeliepower
hallo, ja ärgerlich das ganze
top gelaufen, dann vor einem 3/4 jahr abgestellt und jetzt wollte ich ihn aktivieren und dann das......
bleizusatz mach ich bei jeder tankfüllung rein
dachte erst mein problem ist der vergaser, deshalb hab ich den ganz zerlegt und gereinigt. jetzt muss ich mal schauen, wie ich das teil wieder anständig eingestellt bekomme
hatte die schwimmernadel auch draussen und die verstellschraube von den umdrehungen ungefähr wie es war wieder eingestellt
vielleicht muss ich mich nochmal bei dir melden, wegen einstellung. deutsch geht wesentlich besser, als das gehackte englisch ;-)
obwohl ich bei mail nachrichten auch die "nur" kleinschreibweise und die satzkurzform gern verwende, wie du siehst :rolleyes:
grüße aus dem saarland
manfred
Tractorhead
manfred
Jederzeit gerne
btw. thanks all fellas to help him.
I hope it is ok here to handle that conversation in German, it is easier for him than in English.
Manfred asked how to setup the Carb to basic settings, because he disassembled the whole carb to clean
even main nozzle was completely out.
Is there a howto for the Basic Carb settings available
wheeliepower
I have download the english manual for kohler engines :thumbs:
now i just have to translate with hands and feet and google translate :techie-reference:
  • Haha 2
pfrederi
