Cessna 1 #1 Posted May 4, 2021 I uncovered my old 312-8 with a Kohler Magnum 12 has a few problem. Mostly I needed my other tractor to move the machine. In neutral it is very difficult to push. Any ideas what to look for. 1 Share this post Link to post Share on other sites
Maxwell-8 4,290 #2 Posted May 4, 2021 First up, Wheel Horses are heavy machines, and so always hard to push. Maybe the tranny fluid is so nasty the bearings let go (which is fixable) but that's a hard guess off just some writing words. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,094 #3 Posted May 4, 2021 See if you can get the high/low shifter moved half way between gears. There is not really a genuine neutral there but it may help. Garry Share this post Link to post Share on other sites
oliver2-44 9,848 #4 Posted May 5, 2021 After sittin in one place for a long time these tires can develop flat spots, especially if let get partially flat.. They will re-round with use. Share this post Link to post Share on other sites
kpinnc 12,413 #5 Posted May 5, 2021 Check the brake band for heavy rust too. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,337 #6 Posted May 5, 2021 Has any water gotten into the trans? How is the shifter boot? T😎 1 Share this post Link to post Share on other sites
Tuneup 1,433 #7 Posted May 5, 2021 Ditto on poorly inflated tires. If you just plan to move it, over fill them and it will be a breeze to move. I have old motorcycles (70s) that are the same. Lower the pressure when done. A Honda CB or Kawi KZ are really twitchy with 45 lbs in the tires... 1 Share this post Link to post Share on other sites
stevasaurus 22,861 #8 Posted May 5, 2021 Your tractor is probably just fine. When you push a tractor while in neutral, you still end up turning some gears...ie...your differential carriage, the large mushroom gear and the cluster gear shaft and some of the spline shaft. If the temperature was near freezing, the oil would be thick, if any water, you could have some ice, etc. Along with what was said about the tires, the horse is going to be hard to push. You don't want to force anything, but you should be OK if it was in the fall. Share this post Link to post Share on other sites
