bo dawg 516 #1 Posted May 2, 2021 I pulled the pulley off of the pump cause it was wobbly and it was put on in a bind. My question is about the key way. The pulley slot is bigger than the slot on the pump shaft. Is that correct or maybe a wrong pulley? If correct, where can I find a good correct key? The one I got is a deck spindle key that’s been poorly ground down to half ass fit. I’m guessing that why the pulley was on crooked. Share this post Link to post Share on other sites
JoeM 7,871 #2 Posted May 2, 2021 An offset key may fix your problem. Not sure what you need. Need to measure the shaft key size and the pulley size. Is a straight or woodruff key needed? MMC cares most all common sizes. Or evil bay. 1 Share this post Link to post Share on other sites
bo dawg 516 #3 Posted May 2, 2021 Yes it’s a woodruff key. I will check the site out after I figure what the sizes are. Share this post Link to post Share on other sites
bo dawg 516 #4 Posted May 10, 2021 How can I find out what the pumps shaft size and pully should be? The hole in the pully is a good bit bigger than the pump shaft. Someone had some thin aluminum around the shaft to fit pully better but was still cocked. Share this post Link to post Share on other sites
