evanloock 224 #1 Posted May 1, 2021 Anyone taken one of these cylinders apart? I have removed the pipe elbow from the port closest to the clevis/rod end. The end opposite to the clevis/rod rotates in the cylinder but doesn't appear to screw out of the cylinder. The parts breakdown is not much help. Any advise is appreciated. Share this post Link to post Share on other sites
stevasaurus 22,973 #2 Posted May 1, 2021 Check out this thread, if not what you have, it is going to be real close. Share this post Link to post Share on other sites
pfrederi 18,205 #3 Posted May 1, 2021 On this type of cylinder the pipe fittings are removed then the end caps can come out 3 Share this post Link to post Share on other sites
evanloock 224 #4 Posted May 2, 2021 Thanks for the info! That thread was very helpful Steve. Apparently since the piston was retracted into the cylinder there was some suction working against me. I have it all disassembled now. 1 1 Share this post Link to post Share on other sites
