Gnhuntin
Starting a Clean-up Refurg '90 312-8
Gnhuntin
I bought this about 10 years ago and used it occasionally, mostly as a backup and to mow the dog pen where my zero turn would not fit through the gate.  I installed a larger gate on the dog pen and left this outside for a year when the battery died.  Time to show it some love.  Through the years I purchased 3 new Wheel Horse tractors.  A 308-8, then a 414-8 and finally a 312-H Classic.  My ex kept the classic.  I switched to Kubota for my mowing after owning two Kubota tractors.  Starting a little cleanup on the horse.
  • Excellent 4
Achto
:WRS:
The deck looks awesome!!  :handgestures-thumbupright: Can't wait to see the rest of your work.
WHX??
:text-yeahthat:
JCM
:text-welcomeconfetti:  Great model, my favorite, simple, rugged, sips fuel and very dependable
  • Like 4
Gnhuntin
JCM do you have any pics of the dash, shifter area, etc for decal location placement?  I'm going to order decals from Redoyour horse.
JCM
@Gnhuntin    I do not but could get some and post for you if you need them.  :handgestures-thumbup:
Gnhuntin
Thanks, your tractor looks like it rolled out of the show room.
  • Haha 1
JCM
Went out to the shop and took these for you, @Gnhuntin  hope this helps your refurb. These are as built from  WH in 1989.
oliver2-44
You can go with the " Classic" decal set or the American  flag themed decals that I used on my 1985 312-8  They really make the tractor pop.
Gnhuntin
Thanks for the pictures, had no clue on the location for the caution labels.  I like the classic, the American Flag and the ghost flames.  I paint outside - will need something to hide the paint imperfections.
Lost Pup
Great work on the deck.  To nice to use.
Gnhuntin
It will be used but I will keep it in the garage from now on.
Gnhuntin
I have sandblasted and painted or powder coated every part for the tractor with the exception of the body sheet metal.  Here's a tip - take lots and lots of pictures before and during dissasembly - I was a little lax in doing that.  It would have saved me time in reassembly and would not have to refer to the parts diagrams as often. Here's where I'm at so far.
  • Like 5
  • Excellent 4
Wheel Horse 3D
LOL i think your a bit past that! :ROTF: Lookin Great!
Gnhuntin
Does anyone know of an alternative part # or similar part that will replace the breather hose on my M12?  Looks like the Kohler part is discontinued.
peter lena
@Gnhuntin , good looking work there , might give you a suggestion  that I have incorporated in my 3 horses , is washering in the pto lever , to tighten it up and make it very solid and smooth ,  note the horizontal stack of washers under the battery ground rail ? that was the sloppy pto lever action . use teflon and steel washers and dielectric grease for super smooth action  . also added a 2 bolt flange bearing on steering shaft , and a 4 ga cable from that ground rail to the lower engine corner for grounding issues , also wired my battery tender plug in port to the choke cable for easy operation . good opportunity to add on when building , pete
Gnhuntin
Good ideas Pete, drilled the holes to mount the flange bearing.  Will take the slack out of the pto lever when I put it together.
  • Like 4
kpinnc
Ok, I think there is a rule somewhere here that prohibits showing machinery like that. We old farts that feel lucky to have a drill press are offended at the sight of a mill... :icecream:
  • Haha 4
tunahead72
You have a drill press?!?  Lucky! :)
  • Haha 1
Gnhuntin
The dipstick tube for the transmission broke when I tried to remove it for painting.  I found the outside diameter is the same as 1/2" pvc.  the inside diameter of the original tube is 5/8 (.625) and the pvc electrical conduit I had was .600 I bored out the end to .625 in the lathe but you could use a drill bit.  The charts show pvc should be .622 id.  Maybe the electrical is different, it's what I had on hand so I went with it.  I used a heat gun to soften the broken piece in the threads of the trans and removed it with a curved pick.  The threads in the trans are 1/2 npt.  I used this coupling and a piece of 1/2 pvc conduit and sized the assembly to match the original length.
