Custom front weight bracket.
By
Ifixoldjunk, in Implements and Attachments
Similar Content
By Fordiesel69
Looking for the OEM nelson muffler that fits the Kohler Magnum M10 thru M16 engines found on the following tractor list:
310-8
310-H
312-8
312-H
314-8
314-H
410-8
410-H
412-H
412-8
414-8
414-H
416-8
416-H
and also and "A" models that had the kohler magnum.
I dropped mine off to be welded and it came up missing. It was not good to begin with so im sure they accidentally tossed it out with the way it looked.
By 2drxploder
looking for a tiller for my 520h as well as some wheel weights. also maybe some good chrome hubcaps
located in charlotte nc area
By Donavon
Need ideas to convert my 1054 A Frame plow into a snow blower
Any idea's?
By t_furl43
A Wheelhorse C-165 8 speed, nice solid tractor everything works and operates as it should, all lights works(stack will be removed before sale)unknown hours it was only an option for the 165, but the 16hp single lung cast iron K series motor starts right up and runs strong. It will need new motor mounts. Transmission shifts smooth, package comes with plow w/optional down pressure bar if you choose instead of your trunnions chain, a set of tire chains, a set of Toro brand front wheel weights and a set of generic rear wheel weights, and lastly a full set of hub caps that are in decent shape they can be cleaned up, $1000 obo. Would like to sell as package but if the right buyer was interested in the right combo of stuff for the right amount of money we could work something out. Pickup only in Millersville PA 17551
By OHLB
Newbie here. 310-8 won't start. Battery is dated 10/19. Did crank a couple times but started losing ummph. Should I replace it or attempt to charge it? Can't tell if the battery is frozen. Never knew until today that batteries could freeze and that it's dangerous to charge a frozen battery. It's been single digits with wind chill the last couple weeks here.
