manant
double d mower blades
manant
The mower blades for my 48" mower deck no 65-48ms01 seem impossible to find. The 3 blade kit part number is 100202 and the blades have a double d center hole and two side holes for pins.
Would it be safe to remove the 1/4" spirol pins from the spindle and use a blade with a 3/4"round center hole using a cupped washer and standard bolt?
elcamino/wheelhorse
Check with K & B  in our vendor section they may have a set of  D D  blades.
manant
Thanks, I looked at K&B but did not see any. I posted a request to them but no reply yet.
gwest_ca
Wonder if the blades are too hard to drill so the pins would still drive them?
Use 106637 3-blade set (3/4" round hole)
Garry
Jeff-C175
@76c12091520h
Jeff-C175
deck no 65-48ms01
Is that a typo?  should that be   05-48MS01 ?  Are they really the double D ?  maybe that is the correct number I don't know.
[never mind!  I see that is a good number, disregard please.]
I can tell you that the blades for my 05-48MS01 from 1980 are in fact 3/4" hole and easily found.
Edited by Jeff-C175
my bad
manant
Thanks daveoman!  I have been looking all over for these with no luck until I clicked on your link. I have ordered them - about $60 including shipping.
Thanks again.
76c12091520h
Garry
Can be done; we've done it successfully. Just make sure to retain the 1336  blade washer when doing so. We have a fully outfitted machine shop at our disposal so we're a little more spoiled than most when it comes to things like this.
manant
DANG!  I just got a call from Pat's Small Engine Plus saying the blades are no longer available and they are refunding my $60.  I am still looking.
daveoman1966
I may have a decent set of DD blades for the 48" deck....not sure.
Will check in the daylight am and let you know.
BTW...contact me easier via email.  I am:
daveoman@windstream.net
