Kyle G Cantrell
1971 800 Workhorse restoration help 0100
Kyle G Cantrell
Trying to restore a 1971 Wheel horse Workhorse 800 model 0100, It has a tecumseh HH80-110112D.
I cannot find any parts at all for this one, I’ve checked everywhere I can think online. This is my first restore, looking for some help to find parts or what I can use (swap) to keep it close to original but also functional.
Also the fly wheel has two **** that stick up off it that the coil passes and one is broke off. Is that a problem, I’m a mechanic but this thing is old and with no info it’s a guessing game.
Parts needed so far:
 right side running bored/footrest
Left side engine cover
right side pulley cover
Ignition coil
Main drive pulley bearings
Hitch pin (goes through trans case)
*NEW TO SITE, WILL CHANGE IF POST INCORRECT*
Achto
:WRS:   For these parts you might want to place an add in our classified section.
https://www.wheelhorseforum.com/classifieds/wanted/
  • Thanks 2
SylvanLakeWH
:text-welcomeconfetti:
Retired Wrencher
Kyle  :WRS:   I think to make it easer for you I would just find a 8hp Kholer. Still a good part source. The Tecky parts are drying up fast. But it is up to you. What ever you decide enjoy the project.
Pollack Pete
Sheet metal parts,I would looked for used.If you could find new ones you wouldn't want to know the price.Like others have said,put a wanted ad in the classified section here.Have fun with your project.Looks like a keeper.
Pullstart
I have to ask, it seems there’s a Kyle Cantrell on SXM radio on the Bluegrass Channel.  Any relation, or coincidence?  There are many short frame tractors with floorboards and it shouldn’t be terrible to find one locally.  I believe I have a good one, but wouldn’t imagine shipping one is cheap.
Kyle G Cantrell
Agreed, they are much easier to find!
Kyle G Cantrell
No relation, I think that’s a religious band!
Gregor
I'm still curious about this. :confusion-confused:
512593194_teckypoints.png.91cba56518defa1f7aba2ede80403a05.pngAre you talking about these?  If so, they are called trigger pins. No idea what they do. You need a Tecky expert.
Apparently the censurer prefers "pins" over "T I T S".:D
Edited by Gregor
  • Haha 2
pfrederi
The manual linked above will tell you about the two trigger pins.  Are you sure your ignition module (Solid State) is bad missing pin (trigger) would cause no spark or miss timed spark....?  Used show up on Ebay but they are pricey.  Google Tecumseh Solid State ignition replacement there are some options to modify the ignition system.
Kyle G Cantrell
Thank you!!!!!
Kyle G Cantrell
Poor choice of wording ha ha. And yes those.
  • Haha 1
Howie
Pretty sure both pins have to be there for the ignition to work. Do know they
are at two different heights.
Retired Wrencher
If you can find a no name 8. just switch every thing over. 73 no name I think a where a mistake by W/H.
Edited by Retierd Wrencher
The Tuul Crib
:text-welcomeconfetti:T😎:rs:
:happy-jumpeveryone::happy-jumpeveryone:
Best site on the planet!!
Joe V.
Kyle - I have the same exact tractor all restored fancy so let me help you.
First thing is the two pins on the flywheel... One is supposed to be taller than then the other, it's fine.  [It fires off the taller one during starting as automatic start retard and then the short one when running to advance the timing.]
For the footrest, covers and hitch pin you will have to scrounge around.  Suggest Wheel Horse Junkies on FB. They can help.
As for the Ignition coil, I HIGHLY RECOMMEND you contact
Dale Colvert  262-391-6670
Overnight  Solutions
TCDI II Ignition for Tecumseh
https://www.overnight-solutions.com/Index_Files/TCDI%20II%20Information.html
He can tell you how to measure your stator to ensure it's the module and not the stator (or something else) that's bad.
I just installed one of Dales Ignition Kits and it is EXCELLENT. To get it to fit my HH-80 engine I just had to trim some of the screws on the back and bend the bracket SLIGHTLY so the screws wouldn't ground out on the engine block.  I also filed the slots just a bit on the ends for ease of installation.
Much hotter spark than stock and very noticeable increase in power.
Main drive pulley bearings - It's been a long time since I rebuilt a transmission so I have to pass on that one.  The guys on the FB can help you with that.  I do remember that I got all my flat roller bearings from a bearing and seal specialty house.  MUCH cheaper than Toro/Wheel Horse.
  • Similar Content
    • wh315-8
      By wh315-8
      Picked up a 1972 Commando 800 w/36” rear discharge. From the grandson of the original owner. Hasn’t run in decades but have no doubt that with some cleaning up of carb, fuel system and check the head, it will run like a Horse.
      Has anyone ever seen the steering cap logo like this?
    • AndyZ
      By AndyZ
      Operator manual #A-5274
      Wiring
      6 pages 7.31MB
      Illustrated parts list link
      Use the 1970 parts list for the Raider 10 model 1-6051 and Raider 12 models 1-6251 and 1-6253 with the following exceptions
      For 1970 electric clutch use Electro 12 model 1-7255
      2 pages 282KB
      We also have the 1971 tractor parts manual that followed
      1971 Raider 10 model 1-0300 - (1-0300-6) - Uses HH100-115145C with magneto ignition (Engine oil capacity 2 quarts)
      1971 Raider 12 model 1-0310 - (1-0310-6) - Uses K301S-47407C with breakerless magneto ignition (This model also made in Belgium) (Engine oil capacity 2 quarts)
    • drewd
      By drewd
      I need to buy tubes or new rear tires for my 1971 Workhorse 800.  It has the original 22.5x7.50-12 Wheelhorse branded tires but sidewalls are leaking and one no longer holds air for more that two days.  Searching websites brings up various sizes but not the original.  Would a 23x9.50-12 fit this tractor?  I have a 36" RD deck on it.  Any other sizes work on this rim and tractor?
      Thanks!
