Irhon 2 #1 Posted April 21, 2021 Title really says it all. Was pushing some loose dirt when my GT-14 wheel horse quit moving. Hydraulics still worked fine. I lifted the back off the ground with the lift and grabbed the left rear wheel when to my surprise I could remove the wheel and axle. The shaft is broke about a 1/4" past the beginning of the splines. When i pulled the axle a handful of needle bearings also fell out. So now I'm searching for a new axle and have no idea where i might find one Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,095 #2 Posted April 21, 2021 14-1/8" x 1-1/8" diameter 8055 left axle (1969-1973) replaced by 8054 - No longer available 14-3/4" x 1-1/8" diameter 8054 right axle (1969-1973) - No longer available Share this post Link to post Share on other sites
Irhon 2 #3 Posted April 21, 2021 Well that is unfortunate Share this post Link to post Share on other sites
Jeff-C175 7,203 #4 Posted April 21, 2021 4 minutes ago, Irhon said: Well that is unfortunate Contact Lincoln at AZ TRACTOR, he has good used parts. He's listed in the vendor forum here. Another vendor Brian at K&B HORSE PARTS may also be able to help. 2 Share this post Link to post Share on other sites
953 nut 55,769 #5 Posted April 21, 2021 You may be able to find a good used axle, perhaps A-Z Tractor has what you need. https://a-ztractor.com/ The rear axles from a "D" are a bit longer but have the same splines. 1 Share this post Link to post Share on other sites
Irhon 2 #6 Posted April 21, 2021 (edited) I messaged or emailed them hopefully one of them will have one. Which D series have the same splined 1 1/8th" axles? Also thanks for the welcome! Edited April 21, 2021 by Irhon 1 Share this post Link to post Share on other sites
Irhon 2 #7 Posted April 21, 2021 Does the c-195 twin auto have the same axle spines? Share this post Link to post Share on other sites
19richie66 17,522 #8 Posted April 21, 2021 D160/180/200 all have the same spline (should have) and diameter but are approximately 2” longer than the gt14 axles. The C-195 has an Eaton rear axle..... completely different setup. 1 Share this post Link to post Share on other sites
953 nut 55,769 #9 Posted April 21, 2021 You can get all the gaskets, bearings and seals from Lowell @wheelhorseman, https://wheelhorsepartsandmore.com/ Share this post Link to post Share on other sites
Irhon 2 #10 Posted April 21, 2021 (edited) Ok thank you, while looking through the 'hydro axles' list i seen the 15-7/8" x 1-1/8" diameter 109753 right axle which is for the c-195 and thought maybe that would work too, oh well. Edited April 21, 2021 by Irhon Share this post Link to post Share on other sites
19richie66 17,522 #11 Posted April 21, 2021 You could probably get a longer axle and use it but you would have to have a keyway slot cut into it and then just cut off the extra length. 2 Share this post Link to post Share on other sites
stevasaurus 22,863 #12 Posted April 21, 2021 You might need more then an axle. Your axle broke right in front of your axle gear and maybe some pinions are damaged. I'm going to guess those needle bearings you found mean you have the #111199 needle bearing and not the #1533 ball bearing holding your differential carriage. This file is pinned at the top of the Transmission Section. 2 Share this post Link to post Share on other sites
Irhon 2 #13 Posted April 22, 2021 Yes that was one of the first things i read before signing up to the forums I must be missing something whenever i look up either of those part numbers they are both showing up as ball bearings, neither one of them are needle bearings Share this post Link to post Share on other sites
pfrederi 17,866 #14 Posted April 22, 2021 (edited) I believe the big bearing that the end of the differential rides on is B-348 WH#8048+3 in parts explosion Edited April 22, 2021 by pfrederi 2 Share this post Link to post Share on other sites
Irhon 2 #15 Posted April 22, 2021 After looking at the picture I'm leaning more towards #4 on the diagram. Needles in B-348 look too big 1 Share this post Link to post Share on other sites
Irhon 2 #16 Posted April 22, 2021 I will know for sure when the weather changes back into spring. Share this post Link to post Share on other sites
pfrederi 17,866 #17 Posted April 22, 2021 They look like Outer axle bearings #1526 Torringtnn B-1816 Share this post Link to post Share on other sites
stevasaurus 22,863 #18 Posted April 22, 2021 I believe there is a service order in the manuals section that gives the serial number of the series when they went to the needle bearing. It was because of availability of the ball bearing (1533). You may or may not have it depending on that service order. I only mention it because you pulled out needle bearings...they could be from your outer axle bearing?? Kay Sara Sara...you'll find out when you open it. Share this post Link to post Share on other sites
