cat man
pimped out my tractor
cat man
well i got the rite drive belt for my horse and ha to get a chrome exhaust cover and a chrome coil cover i have a new chrome heat shield cover on the way for the other side to put on my muffler thanks for every ones help
  • Like 6
  • Excellent 3
ebinmaine
Snazzy!
Pullstart
Chrome don’t get you home, but it’ll help you pick your teeth :ROTF:
  • Haha 2
Jeff-C175
  On 4/19/2021 at 7:36 PM, pullstart said:
it’ll help you pick [up chicks] your teeth
Chicks dig chrome!  As long as they can see their reflection in it.
This rooster gets all the chicks!
  • Haha 2
cat man
how tight should you make your deck belt with the nob on the front
Jeff-C175
What I usually do is in the section between the engine and the mule drive, I pinch with thumb and forefinger.  I have a feel for it now, but you should fairly easily be able to squeeze them together.  You obviously don't want it too loose cuz it will slip.  Too tight and it will place unneeded force on all the pulleys.  So the easiest way to say it is to make it tight enough that it doesn't slip while mowing... but that's hard to tell sometimes.
  • Excellent 2
