cat man 137 #1 Posted April 19, 2021 well i got the rite drive belt for my horse and ha to get a chrome exhaust cover and a chrome coil cover i have a new chrome heat shield cover on the way for the other side to put on my muffler thanks for every ones help 6 3 Share this post Link to post Share on other sites
ebinmaine 70,312 #2 Posted April 19, 2021 Snazzy! 1 Share this post Link to post Share on other sites
Pullstart 64,359 #3 Posted April 19, 2021 Chrome don’t get you home, but it’ll help you pick your teeth 2 Share this post Link to post Share on other sites
Jeff-C175 7,203 #4 Posted April 19, 2021 50 minutes ago, pullstart said: it’ll help you pick [up chicks] your teeth Chicks dig chrome! As long as they can see their reflection in it. This rooster gets all the chicks! 1 2 Share this post Link to post Share on other sites
cat man 137 #5 Posted April 19, 2021 how tight should you make your deck belt with the nob on the front Share this post Link to post Share on other sites
Jeff-C175 7,203 #6 Posted April 19, 2021 6 minutes ago, cat man said: how tight should you make your deck belt What I usually do is in the section between the engine and the mule drive, I pinch with thumb and forefinger. I have a feel for it now, but you should fairly easily be able to squeeze them together. You obviously don't want it too loose cuz it will slip. Too tight and it will place unneeded force on all the pulleys. So the easiest way to say it is to make it tight enough that it doesn't slip while mowing... but that's hard to tell sometimes. 2 Share this post Link to post Share on other sites
