Pullstart
Engine Oil Drain... Quick Connect?
Pullstart
Can anyone identify this drain system?  @squonk?  Is there a NAPA # for it?  :D
The oil everywhere under this constituted to a loose oil filter.
It’s the 520Xi, but I doubt it is factory...
squonk
I have seen those before Kevin but never found out who makes it or where they came from.
peter lena
pullstart, does that have a regular pipe thread start? if so there are a lot of options,  similar to the fumoto  spring valve . pete
Pullstart
it’s a pipe elbow above it.  I suppose I could just as easily take the e-z drain do-hicky off an just use a pipe/plug.
peter lena
those threads make it easy , you could also use a ball valve just after the ,elbow , with a hose attached for easy drainage , pete
Jake Kuhn
Stens 125-508 is that style, just make sure the threads are the same.
Pullstart
Hi Jake!  Lot’s changed since we last said hello!  Portage, I think?
gwest_ca
Drain valve looks original.
  • Heart 1
Pullstart
wow, cool!
gwest_ca
Handy Don
That's pretty neat. Does require enough clearance to get a grip on it, though.
Pullstart
I used a blue shop rag and my left hand.  It wasn’t terrible once I saw the picture Garry posted.  :handgestures-thumbupright:
WHX??
Those get used on Z turns alot. My JD has one as well as Cubs that have come through  the shop.
Jeff-C175
That fitting accepts a piece of 1/2" plastic tubing also.  Comes in handy on some machines.  I've got them on a couple machines.  3/8" pipe thread,
Edited by Jeff-C175
shallowwatersailor
The Kohler Command Twin used in the 518xi, 520xi, and 522xi use that drain as well.
