cat man
what WH tractor makes a great puller
cat man
i bought my first WH its a C120 automatic its for cutting grass i put 4 new tires on it and a new head light lens and a good bath but id like to get a puller later on and wondered what WH tractor is used the most and why and are the standards best over an automatic
Maxwell-8
The standards don't slip and they don't get hot.
best to find a Wheel Horse  with a 8 pinion diff and 1" 1/8 axles.
Pullstart
Most any 8 speed will do the trick.  An older 6 speed however (both had 3 forward gears+reverse+hi/low.. but nomenclature changed) will find you with limited slip in the differential.  When you’re super weighted down for pulling, I’m not sure how much that matters...
Lee1977
The pullers found out that the limited slip was not as strong as the 8 speed.
fast88pu
An Early 90s 312-8 is a good start. 12 hp magnum and 1 1/8" 8 speed. Good starter machine for all weight classes depending on club rules
fast88pu
Yeah 10 pinion limited slips were known to break often
kpinnc
When in doubt on 6 or 8 or whatever it says on the hood, AND provided you have 1.125 axles-
Raise both rear wheels so they can spin freely. Roll either rear tire by hand. If the opposite wheel spins the opposite direction, it is NOT limited slip with the weaker diff. If the opposite wheel turns slower in the same direction, you have a limited slip diff.
Edited by kpinnc
Maxwell-8
14 minutes ago, kpinnc said:
1.125 axles
Not only better axles, hubs are stronger, bearings are stronger and off course the diff is twice as strong.
wheelhorsedude
get a c 121
Jimdad85
I posted in the general topic forum and they suggested that i swing by here. I got this at an auction yesterday..i know it needs some work but was interested to know how well she would do as a puller. Any comments or advice would be appreciated. Also looking for a hood i guess. Im told its a 64 1054 c series. Thanks
Edited by Jimdad85
Wild Bill in VA
 The Hydros will over heat due to the over revving  if  a different sized pulley on the input shaft is used. It aerates the oil . Most 3 speed Unidrives will handle up to 35 hp and the 8 speed with the 1-1/8 inch axle and 8 pinion differentials will handle 55 hp before thing start to break. I have pulled every Unidrive and even my RJ-35 with shive belt and never had a problem. My diesel puller uses a 1963 3 speed with heavy duty 1 inch hubs.
Wild Bill in Richmond VA
Wild Bill in VA
On 6/26/2022 at 10:55 AM, Docwheelhorse said:
But.... it just seems appropriate... lol
The Unidrive in this model Wheel Horse used a spider gear type differential and would be very costly to replace (and hard to find) if broken. The axles were strong but unless you knew the history of the transmission ...........
If I remember right there was a way to swap out a later 8 pinion.
fast88pu
You will have to check the rules where you pull for that tractor. Most are 12" max rear rims and also the wheel base.
