cat man 137 #1 Posted April 11, 2021 i bought my first WH its a C120 automatic its for cutting grass i put 4 new tires on it and a new head light lens and a good bath but id like to get a puller later on and wondered what WH tractor is used the most and why and are the standards best over an automatic 2 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #2 Posted April 11, 2021 The standards don't slip and they don't get hot. best to find a Wheel Horse with a 8 pinion diff and 1" 1/8 axles. 1 1 Share this post Link to post Share on other sites
Pullstart 63,498 #3 Posted April 11, 2021 Most any 8 speed will do the trick. An older 6 speed however (both had 3 forward gears+reverse+hi/low.. but nomenclature changed) will find you with limited slip in the differential. When you’re super weighted down for pulling, I’m not sure how much that matters... 1 1 Share this post Link to post Share on other sites
Lee1977 6,915 #4 Posted May 1, 2021 On 4/11/2021 at 9:21 AM, pullstart said: Most any 8 speed will do the trick. An older 6 speed however (both had 3 forward gears+reverse+hi/low.. but nomenclature changed) will find you with limited slip in the differential. When you’re super weighted down for pulling, I’m not sure how much that matters... The pullers found out that the limited slip was not as strong as the 8 speed. Share this post Link to post Share on other sites
fast88pu 3,324 #5 Posted May 1, 2021 An Early 90s 312-8 is a good start. 12 hp magnum and 1 1/8" 8 speed. Good starter machine for all weight classes depending on club rules Share this post Link to post Share on other sites
fast88pu 3,324 #6 Posted May 1, 2021 9 hours ago, Lee1977 said: The pullers found out that the limited slip was not as strong as the 8 speed. Yeah 10 pinion limited slips were known to break often Share this post Link to post Share on other sites
kpinnc 13,068 #7 Posted May 4, 2021 (edited) When in doubt on 6 or 8 or whatever it says on the hood, AND provided you have 1.125 axles- Raise both rear wheels so they can spin freely. Roll either rear tire by hand. If the opposite wheel spins the opposite direction, it is NOT limited slip with the weaker diff. If the opposite wheel turns slower in the same direction, you have a limited slip diff. Edited May 4, 2021 by kpinnc 2 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #8 Posted May 4, 2021 14 minutes ago, kpinnc said: 1.125 axles Not only better axles, hubs are stronger, bearings are stronger and off course the diff is twice as strong. Share this post Link to post Share on other sites
wheelhorsedude 0 #9 Posted June 22, 2021 get a c 121 Share this post Link to post Share on other sites
Jimdad85 12 #10 Posted September 21, 2021 (edited) I posted in the general topic forum and they suggested that i swing by here. I got this at an auction yesterday..i know it needs some work but was interested to know how well she would do as a puller. Any comments or advice would be appreciated. Also looking for a hood i guess. Im told its a 64 1054 c series. Thanks Edited September 21, 2021 by Jimdad85 Share this post Link to post Share on other sites
Wild Bill in VA 1,455 #11 Posted July 8, 2022 On 4/11/2021 at 1:45 AM, cat man said: i bought my first WH its a C120 automatic its for cutting grass i put 4 new tires on it and a new head light lens and a good bath but id like to get a puller later on and wondered what WH tractor is used the most and why and are the standards best over an automatic The Hydros will over heat due to the over revving if a different sized pulley on the input shaft is used. It aerates the oil . Most 3 speed Unidrives will handle up to 35 hp and the 8 speed with the 1-1/8 inch axle and 8 pinion differentials will handle 55 hp before thing start to break. I have pulled every Unidrive and even my RJ-35 with shive belt and never had a problem. My diesel puller uses a 1963 3 speed with heavy duty 1 inch hubs. Wild Bill in Richmond VA Share this post Link to post Share on other sites
Wild Bill in VA 1,455 #12 Posted July 8, 2022 On 6/26/2022 at 10:55 AM, Docwheelhorse said: But.... it just seems appropriate... lol On 9/21/2021 at 8:42 AM, Jimdad85 said: I posted in the general topic forum and they suggested that i swing by here. I got this at an auction yesterday..i know it needs some work but was interested to know how well she would do as a puller. Any comments or advice would be appreciated. Also looking for a hood i guess. Im told its a 64 1054 c series. Thanks I posted in the general topic forum and they suggested that i swing by here. I got this at an auction yesterday..i know it needs some work but was interested to know how well she would do as a puller. Any comments or advice would be appreciated. Also looking for a hood i guess. Im told its a 64 1054 c series. Thanks The Unidrive in this model Wheel Horse used a spider gear type differential and would be very costly to replace (and hard to find) if broken. The axles were strong but unless you knew the history of the transmission ........... If I remember right there was a way to swap out a later 8 pinion. Wild Bill in Richmond VA Share this post Link to post Share on other sites
fast88pu 3,324 #13 Posted July 8, 2022 On 9/21/2021 at 8:42 AM, Jimdad85 said: I posted in the general topic forum and they suggested that i swing by here. I got this at an auction yesterday..i know it needs some work but was interested to know how well she would do as a puller. Any comments or advice would be appreciated. Also looking for a hood i guess. Im told its a 64 1054 c series. Thanks You will have to check the rules where you pull for that tractor. Most are 12" max rear rims and also the wheel base. 1 Share this post Link to post Share on other sites
