tlb41
Carbon Removal Gasket Set
tlb41
I was wondering who all sells the valve grind/carbon removal gasket sets? I like good quality so is genuine Onan the only thing out there? Thanks in advance
onanparts.com
Yes, Genuine Onan are the only "Quality" Made in U.S.A. gaskets, seals etc. out there. ALL other gaskets are cheap garbage from China! The Chinese are copying the Chinese, so the crappy gaskets keep getting crappier....but hey, great source for some Asbestos and cereal box quality gaskets...
We have all genuine Onan parts, no imported junk...
16, 18 & 20 HP decarbon kits are part number 168-0189.
oldlineman
You get what you pay for is my moto! Buy USA
JohnD
What exactly is a "valve grind/carbon removal gasket set"?  All those terms make sense just not as a set.  Must be because I have a Kohler!
lynnmor
What gaskets do you usually replace when you do a valve grind or carbon removal on your Kohler?  :confusion-confused:
Mickwhitt
Head gasket is all that's required for a decoke.  if you are removing the valves then whatever cover you have to remove to access the collets will be needed.
Im no Onan guy so someone will chime in if there is anything else.
Mick
pacer
This is a new ,,,,thing? to me also. A bit of explanation of this please? I've always done as Mick sez - this is a 3 separate steps???
seuadr
no, on the onan (and the kohler) they are separate gaskets, though. so - since it is a twin there are a pair of head gaskets and a pair of valve cover gaskets. on your kohler you are accessing the valves through the breather cover instead, but you should still have a gasket?
lynnmor
On two cylinder engines you may need to remove the intake and exhaust for access, so those gaskets will need to be replaced.
pfrederi
Valve Grind Gasket sets are a common description used for old farm tractors.  Gets you just the gaskets necessary for a valve job.
pacer
Now that makes sense!:thumbs:
JohnD
Ah, the one I haven't done yet!  This will be my first when I get to it!
