ebinmaine 67,627 #26 Posted April 23, 2021 1 hour ago, ranger said: Another YouTube channel worth a look is, “Trev’s Blog”. !!!“WARNING”!!! It can be quite addictive! Doug. I've tripped over that one at some point. Well done.... 1 Share this post Link to post Share on other sites
Pullstart 62,912 #27 Posted April 23, 2021 EB. Do you have room to use two pieces of threaded rod straight through the hood? Use a nut under the frame, above the bottom of the hood, under the top of the hood, then on top, then cut the rod off. 2 Share this post Link to post Share on other sites
ebinmaine 67,627 #28 Posted April 23, 2021 5 minutes ago, pullstart said: EB. Do you have room to use two pieces of threaded rod straight through the hood? Use a nut under the frame, above the bottom of the hood, under the top of the hood, then on top, then cut the rod off. Might? I could even decorate the top of that a little bit with an upside down rubber cup or something. Share this post Link to post Share on other sites
Pullstart 62,912 #29 Posted April 23, 2021 4 minutes ago, ebinmaine said: Might? I could even decorate the top of that a little bit with an upside down rubber cup or something. or leave the studs long and put TWO hood ornaments on? Get you some dualing horses jousting forward... or swiveling like weathervanes to show you what’s up and downhill. Or make ‘em bobble heads looking up hill. Man, I’m on a roll! Time to stop before someone gets hurt! 1 Share this post Link to post Share on other sites
ebinmaine 67,627 #30 Posted April 23, 2021 9 minutes ago, pullstart said: Man, I’m on a roll! Time to stop before someone gets hurt! No no no. Keep going. Keep going. I want to hear whatever other crazy ideas dribble out of your head. Share this post Link to post Share on other sites
Pullstart 62,912 #31 Posted April 23, 2021 1 hour ago, ebinmaine said: dribble out of your head Dribble... the conversations that the girls and I have daily... they’d crack most fellas up on a regular basis. 2 Share this post Link to post Share on other sites
