Ifixoldjunk 778 #1 Posted April 9, 2021 Hi y’all! I’ve been in the process of fixing up a wheel horse 310-8. The original tires are pretty dry rotted and I’ve been thinking about running AG tires. My only issue is the original rear tires were 22x7.50-12 while I can only find 23x8.50-12s. Do you think I could get away with the larger tires and chains? I mostly use the tractor for the snowblower so chains are a must. I don’t want to put the new tires on and not have room for my chains. Thanks for any help✌️ 1 Share this post Link to post Share on other sites
oliver2-44 10,370 #2 Posted April 9, 2021 (edited) You should be able to run 23x8.50-12 or 23x9.50x12 with chains. The 9.5 are 1" wider and will look good and beefy with you front ags. Nice old Bolens ya got there. Edited April 9, 2021 by oliver2-44 1 Share this post Link to post Share on other sites
WHX?? 50,752 #3 Posted April 9, 2021 (edited) I didn't know they made a 9.5 Jim. Always just thought 8.50 and 10.5 Edited April 9, 2021 by WHX24 1 Share this post Link to post Share on other sites
Ifixoldjunk 778 #4 Posted April 9, 2021 45 minutes ago, oliver2-44 said: You should be able to run 23x8.50-12 or 23x9.50x12 with chains. The 9.5 are 1" wider and will look good and beefy with you front ags. Nice old Bolens ya got there. Thanks, if that’s the case I’ll probably go ahead with the 9.50, I want all the traction I can get.👍 Share this post Link to post Share on other sites
Ed Kennell 40,500 #5 Posted April 9, 2021 to the If you plan to use the tractor mainly for snow blowing with chains, I would never buy ag tires. The turf tire will keep more of the chains in contact with the ground than the ag tire resulting in much better traction. 1 3 Share this post Link to post Share on other sites
Ifixoldjunk 778 #6 Posted April 9, 2021 15 minutes ago, Ed Kennell said: to the If you plan to use the tractor mainly for snow blowing with chains, I would never buy ag tires. The turf tire will keep more of the chains in contact with the ground than the ag tire resulting in much better traction. I didn’t think about that, maybe I’ll go with newer turfs or ATV tires.🤔 1 Share this post Link to post Share on other sites
seuadr 489 #7 Posted April 9, 2021 (edited) 58 minutes ago, Ed Kennell said: to the If you plan to use the tractor mainly for snow blowing with chains, I would never buy ag tires. The turf tire will keep more of the chains in contact with the ground than the ag tire resulting in much better traction. depends on the chain pattern i guess. i've got "euro style" diamond chains looks a lot like these: and they sit pretty solid with the ground. with one headlight shroud it looks like your tractor is about to wink, @Ifixoldjunk Edited April 9, 2021 by seuadr 1 2 Share this post Link to post Share on other sites
Achto 28,794 #8 Posted April 9, 2021 I have been eye balling these for my snow plow tractor. I have read some good reviews on their traction on snow and ice, even with out chains. https://www.millertire.com/23x8-50r12-carlisle-versa-turf-compact-radial-tractor-tire-6-ply/ 2 Share this post Link to post Share on other sites
pfrederi 18,334 #9 Posted April 9, 2021 310-8 were made for a few years and changes may have been made...but my 310-8 came with the 22 7.50x12 tires. The wheels were only 5" across not the 7 inch used on most horses . you may find it difficult to mount fatter tires on then and the tires will look distorted. Before buying tires i wuld measure my rims....If you need new rims be sure to f=get them with 1-3/8 in backspace. most garden tractors used 2-3/8 and you would definitely have clearance issues 3 Share this post Link to post Share on other sites
Ifixoldjunk 778 #10 Posted April 9, 2021 1 hour ago, seuadr said: depends on the chain pattern i guess. i've got "euro style" diamond chains looks a lot like these: and they sit pretty solid with the ground. with one headlight shroud it looks like your tractor is about to wink, @Ifixoldjunk I guess it does look like it’s winking lol 1 Share this post Link to post Share on other sites
Ifixoldjunk 778 #11 Posted April 9, 2021 1 hour ago, pfrederi said: 310-8 were made for a few years and changes may have been made...but my 310-8 came with the 22 7.50x12 tires. The wheels were only 5" across not the 7 inch used on most horses . you may find it difficult to mount fatter tires on then and the tires will look distorted. Before buying tires i wuld measure my rims....If you need new rims be sure to f=get them with 1-3/8 in backspace. most garden tractors used 2-3/8 and you would definitely have clearance issues Huh, I’ll definitely have to measure them. Share this post Link to post Share on other sites
oliver2-44 10,370 #12 Posted April 9, 2021 3 hours ago, WHX24 said: I didn't know they made a 9.5 Jim. Always just thought 8.50 and 10.5 I have 9.50 on my C160 and C81. Mine came from a local, giant tire recycle yard, but The Jungle and Bay are full of them. That reminds me I need to make another trip to wander the tire yard. https://www.ebay.com/itm/SET-OF-TWO-Carlisle-Turf-Master-23-9-50-12-4Ply-Lawn-Turf-Tires-511-406/282425285603 1 Share this post Link to post Share on other sites
Pullstart 64,576 #13 Posted April 11, 2021 @Ifixoldjunk 1 Share this post Link to post Share on other sites
OldWorkHorse 3,049 #14 Posted April 11, 2021 (edited) I run AGs on my 314-8, 23x10.5-12 with chains they fit fine other then once in a blue moon a chain would just barly rub on the braket the fuel tank sits in so I ended up putting 2 inch spacers on her to stop the rub. Left tire in photo spaced right tire stock. Edited April 11, 2021 by OldWorkHorse Share this post Link to post Share on other sites
Ifixoldjunk 778 #15 Posted April 11, 2021 5 hours ago, OldWorkHorse said: I run AGs on my 324-8, 23x10.5-12 with chains they fit fine other then once in a blue moon a chain would just barly rub on the braket the fuel tank sits in so I ended up putting 2 inch spacers on her to stop the rub. Left tire in photo spaced right tire stock. Oh cool. So I’d definitely be able to clear at least 23x8.50-12s. Thanks a lot On 4/9/2021 at 9:41 AM, Ifixoldjunk said: Hi y’all! I’ve been in the process of fixing up a wheel horse 310-8. The original tires are pretty dry rotted and I’ve been thinking about running AG tires. My only issue is the original rear tires were 22x7.50-12 while I can only find 23x8.50-12s. Do you think I could get away with the larger tires and chains? I mostly use the tractor for the snowblower so chains are a must. I don’t want to put the new tires on and not have room for my chains. Thanks for any help✌️ I want to thank everyone for there input. I think I’ve finally decided on what tires I’ll get. I’ll probably post something about it once I get them. Thanks y’all 1 Share this post Link to post Share on other sites
