ebinmaine
Here ~She~ goes again...
ebinmaine
17 minutes ago, WHX?? said:
What who when where? :lol:
Some guy in cheeseland.
Why does the head appear to be weird shaped?
:confusion-shrug::confusion-shrug:
Beats me bub.
WHX??
Cats out the bag then... :lol:
  • Haha 1
SylvanLakeWH
I like cheese... :popcorn:
I don't like cats in or out of bags... :hand:
@ebinmaine them cheeseheads are ok don't care what @Pullstart says...
But @WHX?? and @Achto - you guys focus now... focus... Maine ain't on the map...er... route... er... agenda... :ph34r:
  • Haha 4
ebinmaine
Dan n Uncle Jim don't you be listenin' to no Sylvans...
Stop by anytime ya want.
I'll make up some 🤠 .
  • Haha 4
ebinmaine
BBT got the front end of Millie picked up so the transmission can drain.
  • Like 4
ebinmaine
The Paint Department gave the replacement (correct) fuel tank a quick sanding and hit it with acetone.
Some Rust-Oleum 2x primer on now.
  • Like 4
PeacemakerJack
One of these days, this cheesehead and his gang are gonna be rolling up to your barn in Gulliver…
we’ve had the privilege to visit some of the RS members scattered across this great country and one of these days we will make it up to Maine!
  • Excellent 3
  • Heart 1
ebinmaine
Plenty o space!
  • Excellent 2
PeacemakerJack
32 minutes ago, ebinmaine said:
Plenty o space!
For sure…when you travel 35,000 miles per year with a family of six and luggage…Gulliver is perfect. The huge bonus is the 22mpg average fuel economy👍🏻
  • Like 4
ebinmaine
Trina's been sanding and cleaning the engine sheet metal for painting.
Evidently this engine was repainted at some point. There's gray primer under the red. She'll do some more sanding on the inside of the outer cover then spray it.
Gas tank and strap are in color coat now. Tan and black respectively.
Wayne0
On 6/13/2021 at 8:14 PM, ebinmaine said:
More paint ON more parts....
I guess it's better than my or my wife's undies hanging there!
  • Haha 1
ebinmaine
More painting and cleaning and painting today.
She also started getting the engine put back together and scraping the muck.
This'll be painted as it sits after it's cleaned up.
Horse Newbie
My wife had to stop hanging her undies on the clothesline… the dog wouldn’t stop jumping through the leg holes…😝
Edited by Horse Newbie
  • Haha 5
ebinmaine
The Local Disassembly Department has been busy today.
Even the transmission is off now...
@Racinbob my friend you've created a VERY happy BBT tractor restorer !!!
Here's the new ish fan gear.
Already painted flat black.
  • Excellent 2
Racinbob
Now that makes me smile Eric.
I haven't quite figured out the color combo she has planned but I'm liking it.
Great work Trina!
ebinmaine
2 hours ago, Racinbob said:
color combo
All flat.
Black of course.
Khaki.
1920 Army Green. It's a much lighter color than the OD Green.
ebinmaine
After working on disassembly some more Trina spent a bit of time on cleaning the engine block.
She sanded all the surfaces of the breather plates and installed that using new gaskets.
Then the block was attacked with copious amounts of acetone.
Between the two of us we were able to recut the threads in the exhaust. They were REALLY filled with carbon. Only the last two outer threads were open.
All better now.
I got one of the two 6 speed transmissions taken apart.
We'll combine the two we have to make a good one for this tractor then get better gears for the next build.
Even the world famous "Hoobie Doobie" balls made an appearance!
  • Like 5
Handy Don
I’ve been losing a lot fewer small metal parts since I splurged on a couple of magnetic bowls at a Harbor Freight sale.
ebinmaine
Excellent splurge. We have a couple of Mac tools bowls we got from my father's friend Frank cleaning out some camper stuff.
Also a couple of "magnet on a stick".
ebinmaine
The engine and Starter generator got some Army Green paint today.
Note the coat hangin' here...
German Army Green wool
Edited by ebinmaine
  • Excellent 3
ebinmaine
I got the other transuhmashun all dis-parted from its pieces.
Popped the Hi-Lo shifter pin out. AMAZING what ya can do with the right tools.
Checked the bearings. All good.
Cleaned up the gasket surface on the narrow side.
Trina cleaned and painted the two shifters.
Some brackets.
The ignition coil and condenser.
ebinmaine
Me n BBT been fightin' colds and busy this last week.
Finally got a few minutes to get back on this one...
Trina got the engine bolted back down to the work table so she could tighten the oil pan bolts to spec.
I checked the progress on the soaking carb and fuel pump. Should clean up nice.
She finished the torque sequence for the head bolts while I pointed which ones went when.
  • Like 4
Lee1977
She didn't need any help, we know you were just trying to look useful.
  • Haha 4
ebinmaine
Gasket surface block sanded.
Interior cleaned out. Bearings oiled.
  • Excellent 2
