John2189 445 #1 Posted April 4, 2021 (edited) What would I need to put a tiller on the back of my 8 speed c-165? What would one cost? John Edited April 4, 2021 by John2189 Add information Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,033 #2 Posted April 4, 2021 The last one will fit also Here are the models between those above 1980-1982 tiller model 07-36TL01 [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1983-1985 tiller model 07-36TL02 [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1986-1989 tiller model 07-36TL03 [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1990-1991 tiller model 07-36TL04 [Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1992 tiller model 07-36TL05 [Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1993-2001 2003-2007 tiller model 79370 [Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] Share this post Link to post Share on other sites
John2189 445 #3 Posted April 4, 2021 Thanks. Looking at the manuals I’ll need a hitch, belt idlers and the rear lift. Would these parts come with it or would I have to find separately? Share this post Link to post Share on other sites
pfrederi 17,676 #4 Posted April 4, 2021 If you are lucky they will come with it...but i doubt it. Hitch. lift and idler are available from Wheel horse parts and more in our vendor section. When you look at the make sure the tines aren't worn out. if they come to a sharp point they are shot, new tines are available but $$$$$ 1 Share this post Link to post Share on other sites
