19richie66 17,560 #326 Posted December 13, 2022 (edited) 38 minutes ago, scottbrucea said: Richie, So, will he tree a ‘coon? I’m sure he would chase it but wouldn’t know what to do with it when it came down Edited December 13, 2022 by 19richie66 2 Share this post Link to post Share on other sites
c-series don 9,413 #327 Posted December 14, 2022 Lucy just hanging out while I change a fuel injection line. Whatever I bring in my shop she has to sit in or on it !! 4 3 3 Share this post Link to post Share on other sites
ebinmaine 70,494 #328 Posted December 14, 2022 58 minutes ago, c-series don said: Whatever I bring in my shop IS THAT A C SERIES??? @c-series don ??? 1 2 Share this post Link to post Share on other sites
John2189 497 #329 Posted December 20, 2022 I have a heating pad in an open cardboard box set at 100 degrees. A cat’s body temperature is 102. Do you think it’s too hot? He can always get off of it if he does get too hot. It will be below 30 degrees in the garage tonight 4 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #330 Posted December 20, 2022 49 minutes ago, John2189 said: 100 degrees I would turn it down. Something around 70-80. Think about if you would like to sleep on a mat at 96 deg. 1 Share this post Link to post Share on other sites
953 nut 57,706 #331 Posted December 20, 2022 9 hours ago, John2189 said: heating pad in an open cardboard box set at 100 degrees. A cat’s body temperature is 102. I did the same thing for a stray that lived on our covered porch but didn't want to interact with us. There was a blanket folded up on top of the heating pad to insulate it and another blanket draped over the box to retain the warmth. In the spring I unplugged the heat pad but she continued to use the box. Eventually she became our buddy and moved into the house. 2 Share this post Link to post Share on other sites
SylvanLakeWH 27,351 #332 Posted December 20, 2022 8 hours ago, Jeff-C175 said: Think about if you would like to sleep on a mat at 96 deg. Mrs. Sylvan doesn't provide me with a heating mat when I'm in the dog shed... hhhmmm... 8 Share this post Link to post Share on other sites
tunahead72 2,515 #333 Posted December 20, 2022 11 hours ago, John2189 said: I have a heating pad in an open cardboard box set at 100 degrees... 1 hour ago, 953 nut said: I did the same thing for a stray that lived on our covered porch but didn't want to interact with us. There was a blanket folded up on top of the heating pad to insulate it and another blanket draped over the box to retain the warmth. In the spring I unplugged the heat pad but she continued to use the box. Eventually she became our buddy and moved into the house. I'm no expert on the topic, but I would be really concerned about a malfunction in the heating pad, especially at night or any other time it's unattended. The electric pads that I'm familiar with aren't meant to be covered by anything other than the thin cloth pad they sometimes come with. You're also not supposed to sit or lay on them, or otherwise crush them in any way. And a cat could certainly scratch or claw its way through whatever cover is in place and dig into the wiring. I'm all for helping these animals when I can, but I think a simple cardboard box with some blankets would keep them warmer and safer than they would be out in the wild. Maybe there's some other kind of technology that would be safer? By the way, my comments are inspired partly by seeing my neighbor's house catch on fire many years ago, caused by a malfunctioning electric blanket. Fortunately no humans or their pets were injured, but it was frightening to watch, and it wasn't even my house. 4 1 Share this post Link to post Share on other sites
ebinmaine 70,494 #334 Posted December 20, 2022 2 minutes ago, tunahead72 said: claw its way through whatever I have fostered feral cats more than once in the past. They stayed inside my workshop shed over the course of a winter. They were never given heat and it was never a problem. They had small enclosed areas such as transport boxes or cardboard boxes. Blankets in and around or towels or whatever. Given the reminder of the capabilities of a cat I WOULDN'T EVEN CONSIDER leaving a heating pad or heated blanket anywhere within their reach. Especially considering that cats are well known to knead their own sleeping quarters on a regular basis. I appreciate your kind intentions on keeping the animal warmth and I applaud you for it but it is most certainly not worth the risk. Another extremely important consideration to using a source of heat such as that is the designed in duty cycle of the appliance or item. Portable eaters like that are not meant to be left on all the time. I've had a couple experiences at my place. When we had our oil spill a few years ago we were using radiator heaters and one of them began to melt the face off. Another thing is when I had one plugged in to the same outlet in the living room for several months at a time using it off and on. When I went to remove it in the spring I noticed that the off-white colored electric socket was now dark dark gray. 3 Share this post Link to post Share on other sites
John2189 497 #335 Posted December 20, 2022 The cat pad has been on now since the beginning of November. It is set at 100 degrees. The infrared temperature when he is off of it is an average of 48 degrees. When he just gets off of it the reading is about 85 degrees. I do check it to see if he scratches it and he doesn’t. He can get off of it if he gets too hot. It is in a cardboard box on a cement floor away from any combustibles. thanks for all your advice and suggestions, i was just concerned if it was too hot. 3 1 Share this post Link to post Share on other sites
ebinmaine 70,494 #336 Posted December 20, 2022 1 minute ago, John2189 said: It is in a cardboard box on a cement floor away from any combustibles Sounds like you're doing the right thing overall John. Probably wouldn't bother the cat (or hurt your energy bill) if you could turn that heater down. One thing to keep in mind on that set up... even though it isn't near other combustibles... is that if it short circuits it could overheat the plug.... 2 Share this post Link to post Share on other sites
Horse Newbie 7,195 #337 Posted December 20, 2022 (edited) Bailey in his monkey Jammie’s… Edited December 20, 2022 by Horse Newbie 3 2 4 Share this post Link to post Share on other sites
Jeff-C175 7,203 #338 Posted December 20, 2022 (edited) I've talked about this before... but I'll repeat it any way. Many years ago we had a 'shop cat' named "Stymie". I built a 'cat house' for him. It had a swinging door on it (duct tape hinge). It was highly decorated. Over the door: "He-Cat Mouse Haters Club" and much more. Wish I had pictures. I had a thermostatically controlled heater inside. Used some old boiler controls for that. It was set to 50°F. The heater was a 40W bulb in a metal box with a several vent holes. Placed it on a pallet to keep it off the floor with a piece of foam insulation underneath. I also had foam insulation on the side that faced (but not touching) the block wall on one side. Stymie was very happy with his "Kitty Klubhouse". 1 hour ago, John2189 said: set at 100 degrees I still think that's too hot. Edited December 20, 2022 by Jeff-C175 1 Share this post Link to post Share on other sites
John2189 497 #339 Posted December 20, 2022 5 minutes ago, Jeff-C175 said: I've talked about this before... but I'll repeat it any way. Many years ago we had a 'shop cat' named "Stymie". I built a 'cat house' for him. It had a swinging door on it (duct tape hinge). It was highly decorated. Over the door: "He-Cat Mouse Haters Club" and much more. Wish I had pictures. I had a thermostatically controlled heater inside. Used some old boiler controls for that. It was set to 50°F. The heater was a 40W bulb in a metal box with a several vent holes. Placed it on a pallet to keep it off the floor with a piece of foam insulation underneath. I also had foam insulation on the side that faced (but not touching) the block wall on one side. Stymie was very happy with his "Kitty Klubhouse". I still think that's too hot. What temperature do you recommend? 80 degrees is the lowest 1 Share this post Link to post Share on other sites
ebinmaine 70,494 #340 Posted December 20, 2022 2 minutes ago, John2189 said: What temperature do you recommend? 80 degrees is the lowest I'd put it at whatever the lowest possible temperature is. Most Cats are covered with hair for a reason. All you really want to do is keep it so it's above a point of freezing. 1 Share this post Link to post Share on other sites
John2189 497 #341 Posted December 20, 2022 18 minutes ago, ebinmaine said: I'd put it at whatever the lowest possible temperature is. Most Cats are covered with hair for a reason. All you really want to do is keep it so it's above a point of freezing. Thanks mabey I will set it to 90 tonight and 80 the next night 1 Share this post Link to post Share on other sites
ebinmaine 70,494 #342 Posted December 20, 2022 3 minutes ago, John2189 said: Thanks mabey I will set it to 90 tonight and 80 the next night Why the temperature gradient? To acclimate the cat? Given the fact that it likely switches on and off to some extent and also the fact that the cat is likely not in there 100% of the time I should think probably you could go ahead and switch it right away. 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #343 Posted December 20, 2022 13 hours ago, Jeff-C175 said: would turn it down. Something around 70-80. 27 minutes ago, John2189 said: What temperature do you recommend? 80 degrees is the lowest As earlier, 70-80 , so just set it at it's lowest. Kitty will be fine. 1 Share this post Link to post Share on other sites
Rob J. 1,942 #344 Posted December 20, 2022 My girl. 3 1 4 Share this post Link to post Share on other sites
John2189 497 #345 Posted December 20, 2022 4 hours ago, Jeff-C175 said: As earlier, 70-80 , so just set it at it's lowest. Kitty will be fine. Jeff, sorry I must have missed this post. 1 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #346 Posted December 20, 2022 2 hours ago, Rob J. said: My girl Looks like our cat from years gone by. We had one that was all gray like that also. Ours was a He-cat. BIG!!! not fat, but MUSCLES! He hadda go almost 18 pounds or so. He had the best personality too. Is that a "Russian Blue" by chance? We believe ours was, but no way to tell without "38 and me" genetic testing and if he was on the FBI wanted list... well, we didn't have him tested... 1 1 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #347 Posted December 20, 2022 17 minutes ago, John2189 said: Jeff, sorry I must have missed this post. Nota problema John! All good... 2 Share this post Link to post Share on other sites
ebinmaine 70,494 #348 Posted December 20, 2022 14 minutes ago, Jeff-C175 said: if he was on the FBI wanted list... well, we didn't have him tested... Some things ya just don't wanna know. 3 Share this post Link to post Share on other sites
Rob J. 1,942 #349 Posted December 20, 2022 44 minutes ago, Jeff-C175 said: Looks like our cat from years gone by. We had one that was all gray like that also. Ours was a He-cat. BIG!!! not fat, but MUSCLES! He hadda go almost 18 pounds or so. He had the best personality too. Is that a "Russian Blue" by chance? We believe ours was, but no way to tell without "38 and me" genetic testing and if he was on the FBI wanted list... well, we didn't have him tested... Not sure Jeff. I got it from the humane society for my wife but she ended up being my cat. They say pets are a better judge of character than people are, so I’ve heard. 😜 No seriously my wife is the best just so busy she didn’t have the time I did with her. Thought we almost lost her a couple weeks ago. She didn’t eat, drink, duty for almost 2 weeks. Spent a ton of money at the vet only to find out they didn’t know. Then she started pulling through. 1 3 Share this post Link to post Share on other sites
Horse Newbie 7,195 #350 Posted December 21, 2022 Bailey is sporting his Duckie Jammie’s tonight… cozy doggie… 1 3 Share this post Link to post Share on other sites
