seuadr
Mackissic mighty mack shredder on 520h
seuadr
Anyone know what size belt this thing takes?
Kinda looks like around 84"?
  • Excellent 3
gwest_ca
ebinmaine
Cool chipper.
I have one here I'll be putting on a C160.
Being a non Wheelhorse implement it may be a measure to fit...
ebinmaine
I'd love to see close-ups of the bracket system.
seuadr
@gwest_ca thanks for the link, unfortunately the belt is listed as "belt" no size :/ it came with a 78" belt but that isn't long enough, i am assuming because the 520H is longer.
@ebinmaine i can get some tomorrow. it matches up to holes that were already in the wheelhorse frame and has a couple spacers to make it tight to the frame it is pretty simple.
big problem i need to figure out is the front set of bolts are between the steering and the front tach-a-matic point and i can only get a couple fingers in there to hold a bolt, and there isn't enough room to feed a bolt in backwards so that it sticks out of the frame towards the tire cause you can't get a straight shot. not really sure what to do with it, may have to take the axle off so there is clearance and put a threaded stud in or something.
gwest_ca
Click on the picture in the link.
Lane Ranger made a call to them and I posted the info on the file description page.
There are three belts there
MacKissic Number Belt # / Regular Belt Size
506-0003 / 4L-780
030-0073 / 4L-810
030-0126 / 4L-840
These are all 1/2 wide 5/16th deep.
The drawing shows a 3/8" rod threaded on both ends. The flat washers listed are 5/16 so must be USS and 3/8" nuts.
seuadr
506-0003 / 4L-780
030-0073 / 4L-810
030-0126 / 4L-840
thanks! i just clicked on the download link to see if it was different than the one i found earlier - i didn't realize there was a page.
84"  looks like the longest one, and 84" i what i measured so 84" is what i will try!
ebinmaine
@seuadr
Absolutely awesome!!!
THANKS.
@Stepney is yours set up like this?
seuadr
8 hours ago, ebinmaine said:
@seuadr
THANKS.
no problem. you can see in the picture that it is angled down, i don't know if that was intended for operation or if it is just because my front bolts are only finger tight because i can't get in there.
Stepney
11 hours ago, ebinmaine said:
@seuadr
THANKS.
I feel like mine is a little different than that but it may be older. Same basic look. Mine is closer to the hood, the extra space would be welcome haha.
I know mine uses an 80" belt but that's on an 1968 Electro.
ebinmaine
The bars that go from the front mount square and bolt directly to the frame...
Are those just 3/8" x (2"? Or 2-1/2"?) bar stock welded to the mount??
seuadr
2" tall, 1/2" thick. looks like bar stock.
ebinmaine
Looks like this will be an easy conversion for me. EXCELLENT.
Lee1977
You could use a treaded rod to go all the way trough.
Edited by Lee1977
seuadr
so, just occurred to me, i need to check and see if this clears the mule drive - if it does, i could leave this on all the time and use it as a weight rack the rest of the time! (until it was time for snow blowing..)
ebinmaine
Sounds like a reasonable idea.
Looks like those brackets would be wide enough to clear...
seuadr
did you fab up your own bracket yet? if not, i got one for you...
ebinmaine
Not yet, no.
You have an extra?
seuadr
4 minutes ago, ebinmaine said:
Not yet, no.
You have an extra?
so, @ACman gave me another parts chipper, and i already have a bracket, so i don't need two. i figure, he gave it to me, i'll give the extra bracket to you, save you some time fabbing one. i just gotta figure out shipping?
Edited by seuadr
i no speel gud.
ebinmaine
Normally I use USPS just because of ease.
We also get FedEx and UPS here at the house if either one of them is easier for you...
I'll PM you my address.
I'd be every kind of happy and then some to get a hold of that!
gwest_ca
Is the chipper running 2600 +/- 200 rpm?
What did you do to level it up?
Garry
ebinmaine
Is that the recommended rpm setting?
@seuadr sounds GREAT
seuadr
Garry
I assume, i have the tractor running at ~ 2500 rpm and the pully in the chipper is about the same diameter so
