Jhawkins
1968 commando 8 3 speed Belgium tractor
Jhawkins
I’m looking for information on what I believe  is a 1968 commando 8 3 speed Belgium tractor. It has a vertical shaft engine.
stevasaurus
Are you sure it is a 1968??  Do you have a model number??  What type of engine...Lauson, Kohler, Tecumseh??
1968 Commando's from Belgium...vertical shaft...none...  1969 & 1970 did have some Lauson V 70's and Kohler KV181S
USA...1969...Kohler  KV181S
Jhawkins
Based on the decals I say it’s a 1968. I’ll have more information Saturday
stevasaurus
A model number would solve any problem.  It really looks like a 1969...it has more options with some state side.  You just don't see many Belgium horses this side of the pond...especially vertical shaft.  :dunno:   Saturday!!  :occasion-xmas:
Rfp55
I have a 69 charger with THAT 8 hp vertical Kohler on it. The 500# weight (heavy cast front subframe) will get loads of work done with the tractor - and the engine in mine mainly needed some digging into the ignition module block to attach the trigger/ground switch where the spade had broken off. I don't have info you're seeking on Belgian horse but 8 & 10 hp were the big models once and worked fine. In my use they will do an acre of grass on half of what the 20 HP uses. The air filter element will be hard to find and muffler scarcer if need one though. Very small turning radius and quick steering may make it favored over large models. You do get into tight places with a 36" deck nicely. Good find.
