squonk
Yes , Close calls do count in Hand Grenades!
stevasaurus
So, what boat are you going to use that on???   :ROTF:
  • Haha 6
stevasaurus
Don't you scare my Tecumseh !!  :hide:  :orcs-cheers:
  • Haha 5
pfrederi
Those are the old style balance gears...  Wonder if they changed design because of excessive failures the older ones.  Are the grenade incidences relate mostly to old style...or evenly distributed???
squonk
I don't know Paul but I'm sure glad I stopped using it when I did.
stevasaurus
Live bacon is an option.  :ROTF:
  • Haha 6
richmondred01
How does the apron skirt of the cylinder look?
Thats the big concern is that cylinder apron skirt that extends into the block.
Check for any cracks or splits with that skirt. If none, go out and buy a lottery ticket.
squonk
I don't have the best eyes but I didn't notice anything with the piston up or down
AMC RULES
Bet you, if there is something to see in there, someone here will surely point it out. 🤣 🙈 🤣
squonk
Going to pull the piston tomorrow and take a good look. Use the Handyman's Secret Crack finder, Carb cleaner. Pics to follow!:banana-wrench:
  • Like 6
squonk
oldlineman
Just a question, did the M series engines have these gears? And if so have they had the same problem as the K series or was there an improvement in design. Bob
Edited by oldlineman
pfrederi
M singles can have balance gears
squonk
As Jim Lovell in Apollo13 said "There's one whole side of that spacecraft missin!" hard to believe this engine was still running fine!
  • Haha 1
  • Confused 2
  • Heart 1
Handy Don
Only a matter of time 'till you had a complete ruin. Definitely dodged a bullet there!
Sometimes that Kohler engineering just astounds, doesn't it?
oldredrider
Had a K321 rev to the outer limits one time. Ran fine but decided to tear it down to see what was going on. Piston had shattered and pieces of it took out several teeth on the governor gear. Still ran fine but glad I took it down. Lucky me!
richmondred01
A couple minutes more and you would be seeing this.
  • Like 4
  • Sad 3
WHX??
I'll see your pan and raise ya a cam...
  • Sad 2
squonk
At least mine was still running! :)
  • Haha 2
WHX??
Bet yours had oil in it too. Dang kids... we all know what would have happened the rod went the other way! Happened at plow day... even got a video of it letting loose somewhere on here.
Edited by WHX24
Gregor
When you say rattle, you mean like a bowling ball in a clothes dryer?
squonk
Almost like pinging
Edited by squonk
