Vintner 17 #1 Posted March 27, 2021 I have a WH tractor that was made the year WH was bought out by Toro (1984?). I've had a real issue finding parts because I can not find a model number anywhere on it. (I know the year is was made because of the number on the engine.) I need a new belt for the deck. Not the one that goes from the engine to the deck. The one on the deck itself. There's a "ID #" on the deck which is 1542RC01 followed by a BIG space, then 12389. Could this be the model number for the entire tractor or just the mower deck? How do I go about finding a new belt? Share this post Link to post Share on other sites
pfrederi 18,103 #2 Posted March 27, 2021 Does this look like your deck?? Manual is had o follow but if yours is 42" Rear discharge deck belt is WH 106125 Share this post Link to post Share on other sites
pfrederi 18,103 #3 Posted March 27, 2021 Easier to follow. 1 Share this post Link to post Share on other sites
Vintner 17 #4 Posted March 28, 2021 Thanks for the quick help pfrederi! I hope that is the right one. I went ahead & ordered it. Have a great weekend. Share this post Link to post Share on other sites
Tach-a-matic 357 #5 Posted March 28, 2021 I have the same exact model deck and the belt is 89" (which WH10625 is). You'll need a strong J hook or spring puller at (A) to take tension off and its a good time to lube the sliding tensioner mech (B), hit the the grease fittings on the tops of the spindles (3-4 pumps?) and sharpen the blades too! Share this post Link to post Share on other sites
