pfrederi
Valve cover leaks
Handy Don
7 minutes ago, pfrederi said:
Even correctly installed I have had several Kohlers that weep oil from the valve cover.  I hate using sealant as it makes disassembly for cleaning  very difficult.  I recently made a discovery that Kohler must have noted the problem and changed very slightly the design of the cover.  I have put a new version on with no sealant and so far after a few hours no seepage.  The little ridge around the cover on the sealing surface bites into the gasket and also may provide a bit more resistance to bending,  New on the right.
Engineers, those wily wascals.
  • Haha 2
ebinmaine
How does one go about procuring a new version?
Stepney
Funny that, I've always just run a sharp file along each edge a time or two, old Mercedes diesel mechanic showed that and it works on just about everything. Never seen that part though, wonder when it changed?
pfrederi
Order one:P  I am assuming new in this case is several years ago...
Edited by pfrederi
  • Haha 1
ebinmaine
10 minutes ago, pfrederi said:
Order one
Hahahaha..
That works. .....
pfrederi
6 minutes ago, ebinmaine said:
Hahahaha..
That works. .....
PMed you
Pullstart
create an edge towards the inside, great idea!  I just opened a package today and caught an un-deburred edge on my finger... filleted it right open!
  • Sad 2
Stepney
I'm a machinist so I'm always terribly nervous of burrs of any sort.. Not terribly fun when you notice there seems to be just one corner of your finger tip actually attached..
  • Sad 1
Jeff-C175
I sometimes don't even notice that I've been 'vented' until I see blood smears on what I'm working on.
  • Haha 3
Pullstart
I worked tool and die in the mill dept. for a few years out of High School.  Cleaning milled edges when applicable makes such a huge difference for handling!
Stepney
Indeed.. I got a pretty good snag once grabbing a napkin off the floor..
Huh, well the thing was dry a second ago, how'd it .. uh oh.
Hey, boss! You got a roll of tape and a good clean cloth??
Haha.. ouch. Just about stripped right hand little finger.
On the topic though.
Good friend used to rebuild and service Merc diesels. The large truck sort, not the passenger cars. Apparently an old cure-all for random blown head gaskets was to simply drag a file along the affected area.
Funny, of all the other old machines I dealt with and all the farmer repairs, I've not heard that one again before or since.
elcamino/wheelhorse
Off Topic  wait till you start taking 81 mg aspirin daily blood drains out of you even you have a small pin hole puncture.
  • Sad 2
Jeff-C175
Don't have to wait!
