chev0545
1998 314-8
chev0545
got a new switch by the gear shift lever.can't figure out how it fits.
thanks
gwest_ca
Not aware of this info in any manual. Perhaps the illustrated parts pages will help. You can enlarge these
https://www.partstree.com/models/73448-314-8-toro-garden-tractor-sn-089000500-089099999-1998/transmission-assembly-29/
https://www.partstree.com/models/73448-314-8-toro-garden-tractor-sn-089000500-089099999-1998/hoodstand-console-19/
If these do not help post the part number of the switch.
Garry
953 nut
:confusion-questionmarks:      Are you talking about the Parking Brake Safety Switch on the plate under the shift lever?           :wwp:
Edited by 953 nut
chev0545
plate under shift lever
chev0545
does the silver tab go towards the e brake slot?
Pullstart
Maybe it’s a reverse light switch?  I picked up a 1045 for @Rp.wh last year.  It had a switch on the left side of the frame by the “z” bend in the brake rod.  It actually had brake lights!
OldWorkHorse
On my* 314 the sping tab goes toward the ebrake lever so when u push the ebrake forward it will engage the switch.
Edited by OldWorkHorse
Fat thumbs*
chev0545
do you know if that solve the problem when you go to put in gear it won't shut off
Bill D
Is it a newer model with the neutral safety switch?  Pictures would help.
OldWorkHorse
No I dnt but there are like 6 safty switches on mine and if any of them arnt working can give you problems. My dash also has a dummy check light list so tells me what safty Is working or not engaged.
gwest_ca
The 1998 314-8 is the only model that is not in the Demystification Guide so no illustrations for each circuit. May try to make some.
Big change to what we are used to seeing.
Garry
Made up 4 pages than explains how it works.
chev0545
  • Similar Content
    • mooman3121
      By mooman3121
      Love them red tractors!  My 855 that I mow with, RJ58 for road cruises, 702 for ornament, and 657 for moving whatever!
    • ebinmaine
      By ebinmaine
      Could you folks please post a pic or two of your coil mount bracket on a Kohler 8?
      Mine is on a vertical Mount beside the engine and it's vibrates quite a lot. Not sure if that should bug me too much but I always thought coils and vibration were not friends.....
      Thanks
    • Geno
      By Geno
      Walked out the back door yesterday morning and saw something cool.  Thought you guys may have some cool stuff to share this Winter too.
