Tach-a-matic 357 #1 Posted March 22, 2021 (edited) The original plastic seat pan held reflectors only and I cannot see any taillight wiring under the pan to indicate otherwise. However the parts breakdown shows taillights. Was this an option? The switch on the tractor has two tabs - one for power and one going to the headlights. Yet the manual shows three wires going to a two pole switch (huh?) Think I can splice into the existing headlight wire and run it to the rear for a small LED spotlight? Or should I add a three tab switch? Edited March 22, 2021 by Tach-a-matic Share this post Link to post Share on other sites
ebinmaine 69,834 #2 Posted March 22, 2021 15 minutes ago, Tach-a-matic said: small LED There's your key. Most all LEDs have such a small amp draw you should have no issue. Definitely need to confirm specs on whatever you buy. 4 Share this post Link to post Share on other sites
pfrederi 18,205 #3 Posted March 22, 2021 As for your connector they probably crimped both wires into one terminal. Or you could use a piggy back connector like one of these. 5 Share this post Link to post Share on other sites
Tach-a-matic 357 #4 Posted March 22, 2021 Never saw that piggyback style connector before (I learn something every day!) I am installing LED front bulbs as well so the total load on the switch should be decreasing even if after I add an LED light in the rear 3 Share this post Link to post Share on other sites
SPINJIM 1,981 #5 Posted March 22, 2021 If you're installing a SPOTLIGHT that you will want to use independently of the headlights, I would install a separate switch, and run a fused line back to the spot light. I installed tail lights on my C-85, and just spliced them into the line coming off of the headlight switch. No problem. Jim 2 Share this post Link to post Share on other sites
Mickwhitt 4,903 #6 Posted March 22, 2021 I fitted new led headlights to Fred, they take their feed from the headlight switch but have a separate switch wired into the system to allow an automatic flash function. Mine was fitted with tail lights but on a roll over frame so probably not original. They are the same type of light as I've seen on other WH models. I stripped out the bulb interior and fitted in an led marker light which works great under the original light lens. Well worth upgrading the lights. 2 Share this post Link to post Share on other sites
midpack 938 #7 Posted March 22, 2021 One thing I found out about LED's last winter. Electric lift, Electric PTO, and LED add on headlights can eat up your battery charge quicker than it can be replaced... but what a difference they make Anybody have a 25 amp stator for a Magnum 18 they want to part with? 1 Share this post Link to post Share on other sites
SylvanLakeWH 26,649 #8 Posted March 22, 2021 I just tied in an led trailer light to the head light / tail light wire and wired it for the “brake” light... got quite a nice red flood light for night plowing... 2 Share this post Link to post Share on other sites
ebinmaine 69,834 #9 Posted March 22, 2021 3 hours ago, midpack said: One thing I found out about LED's last winter. Electric lift, Electric PTO, and LED add on headlights can eat up your battery charge quicker than it can be replaced... but what a difference they make Anybody have a 25 amp stator for a Magnum 18 they want to part with? @OldWorkHorse Steve and I have talked about adding a small alternator a time or two. Share this post Link to post Share on other sites
pfrederi 18,205 #10 Posted March 22, 2021 3 hours ago, midpack said: One thing I found out about LED's last winter. Electric lift, Electric PTO, and LED add on headlights can eat up your battery charge quicker than it can be replaced... but what a difference they make Anybody have a 25 amp stator for a Magnum 18 they want to part with? Something is wrong here. Electric PTO draws 4-5 amps, Engine draws nothing running (Magneto) Head lights even old incandescent 35watts x2 (5.88 amps) you are still less than 10 and i doubt you run your lift continually.. Have you load tested your battery lately??? 3 Share this post Link to post Share on other sites
Tach-a-matic 357 #11 Posted March 23, 2021 (edited) Tonight I replaced the 72 watts of halogens with 24 watts of LED's. ...and picked up some piggyback connectors (thanks for the tip!) and ran a wire from the switch out to the back for a 6W light. I "sacrificed" the real estate of a p-side reflector and mounted it in its flat mounting area. It seems to work okay, no probs, and puts out decent light Yesterday I painted the seat pan Regal Red but it looked awful because it was so pitted. Went a little "out there" and painted it with bedliner paint to hide all the pitting and get some kind of uniform finish going. I know its not red, and I dont really like it in black myself, but its what I got to work with. The rear light is now where the right reflector was Edited March 23, 2021 by Tach-a-matic 2 Share this post Link to post Share on other sites
Daddy Don 907 #12 Posted March 23, 2021 I put running lights on my c-125 front and back and never have had any problem with them. did not use leds. Use the wiring that is shown on the start of this question. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,187 #13 Posted March 23, 2021 I added an automatic back-up led lamp to the C-120 8-Speed. Used a 20 amp relay to control it powered by the original light circuit so the original lights need to be on for the back-up lamp to work. That way the back-up lamp will not get accidently left on. The led back-up lamp is powered by the battery. It has worked flawlessly for about 6 years now. A magnet is clamped to the shifter and when it gets close to a chassis mounted reed relay on comes the light. Great for plowing snow in the dark. Garry 3 Share this post Link to post Share on other sites
midpack 938 #14 Posted March 23, 2021 12 hours ago, pfrederi said: Something is wrong here. Electric PTO draws 4-5 amps, Engine draws nothing running (Magneto) Head lights even old incandescent 35watts x2 (5.88 amps) you are still less than 10 and i doubt you run your lift continually.. Have you load tested your battery lately??? It was a brand new 300 CCA battery last fall. Soon as I unplugged the LED's, no more problem with the charge. Now that it's not freezing cold I can dig into it more Share this post Link to post Share on other sites
Tach-a-matic 357 #15 Posted March 23, 2021 (edited) relocated the light a la Mr Sylvan Lake's spot Edited March 23, 2021 by Tach-a-matic 1 1 Share this post Link to post Share on other sites
Tuneup 1,433 #16 Posted March 24, 2021 My 125 came with rear lighting, not that the pan was in any shape to be retained. That krinkle finish is a nice base for a Regal Red overspray, right? I'm assuming that finish can be painted - maybe not. Nice job on the lighting! Share this post Link to post Share on other sites
