over60pirate 24 #1 Posted March 22, 2021 Anyone put a suspension seat base on their Wheelhouse (414-8) ? Got on mine after 2 years of using a zero turn to cut grass, that had a suspension seat base. Horse was a bucking. Thinking of putting a suspension seat base on the WH. Also, what is the minimum f & r tire pressures? Might help. Got 14 in back and 12 in front. Lots of bumps in lawn. Will be using WH for towing grass catcher to pick up leaves, aerator, plow for leaf pile, and towing trailers around property. Except for my back, it felt great to get back on her. Great machine. Share this post Link to post Share on other sites
ebinmaine 69,568 #2 Posted March 22, 2021 (edited) 47 minutes ago, over60pirate said: , what is the minimum f & r tire pressures? Might help. Got 14 in back and 12 in front Should be 8 rear, 12 front on older models. I run even less. See @JCM Jim's post below for 3/4/500. Edited March 22, 2021 by ebinmaine Changed/added info. 1 Share this post Link to post Share on other sites
JCM 9,900 #3 Posted March 22, 2021 For point of reference a 300 400 500 series according to owners manual 12 psi front and rear. 2 Share this post Link to post Share on other sites
roadapples 6,983 #4 Posted March 22, 2021 I have suspension seat on my C160 with loader and hoe... Share this post Link to post Share on other sites
ebinmaine 69,568 #5 Posted March 22, 2021 25 minutes ago, JCM said: For point of reference a 300 400 500 series according to owners manual 12 psi front and rear. Ok cool. Thanks Jim. I'll edit my post. 1 Share this post Link to post Share on other sites
pfrederi 18,115 #6 Posted March 22, 2021 Interesting up through the C series 12 front 8 rear. Wonder why they changed for later models... 1 Share this post Link to post Share on other sites
Rusty Tinsnips 477 #7 Posted March 22, 2021 Can a spring system be added to the seats that bolt right to the fender pan? Share this post Link to post Share on other sites
squonk 41,840 #8 Posted March 22, 2021 4 minutes ago, Rusty Tinsnips said: Can a spring system be added to the seats that bolt right to the fender pan? U-channel springs are easy to do. 2 Share this post Link to post Share on other sites
Rusty Tinsnips 477 #9 Posted March 22, 2021 1 minute ago, squonk said: U-channel springs are easy to do. Will that hold up a fat guy? Maybe a stiff coil spring at the back. Share this post Link to post Share on other sites
JCM 9,900 #10 Posted March 22, 2021 18 minutes ago, ebinmaine said: Ok cool. Thanks Jim. I'll edit my post. I was not sure if the C-Series were different that 's why I specified 3 4 500 were 12 psi front and rear. In actuality Leo my WH dealer since 1965 who some of you met at the Sept M&G still calls the 3 4 and 500 C-Series because that's what they really are to some degree, I would agree. 1 Share this post Link to post Share on other sites
over60pirate 24 #11 Posted March 22, 2021 31 minutes ago, Rusty Tinsnips said: Will that hold up a fat guy? Maybe a stiff coil spring at the back. Maybe I should have asked about minimum tire pressures. I'm towing a lawn sweeper and it works better with a higher speed. 1 Share this post Link to post Share on other sites
pfrederi 18,115 #12 Posted March 22, 2021 Much below 4-6 lbs you may run the risk of the bead coming loose on side hills or tight turns.. 1 Share this post Link to post Share on other sites
squonk 41,840 #13 Posted March 22, 2021 1 hour ago, Rusty Tinsnips said: Will that hold up a fat guy? Maybe a stiff coil spring at the back. I'm 250 if that helps! Share this post Link to post Share on other sites
Ed Kennell 39,648 #14 Posted March 23, 2021 (edited) Here's the suspension seat I just installed on my 417H. I need to switch to lighter springs. With it set on the minimum tension, my 180 lbs isnt enough to hold it down Edited March 23, 2021 by Ed Kennell 1 Share this post Link to post Share on other sites
roadapples 6,983 #15 Posted March 23, 2021 (edited) Eat more pizza Ed... Thats the same one I've got on mine, but I'm about 60lbs heavier.. Edited March 23, 2021 by roadapples 2 Share this post Link to post Share on other sites
ebinmaine 69,568 #16 Posted March 23, 2021 8 hours ago, Ed Kennell said: 180 lbs 5 hours ago, roadapples said: 60lbs heavier Buncha lightweights.... 🐻 🐻 🐻 🐻 🐻 2 Share this post Link to post Share on other sites
