ricksrj58 273 #1 Posted March 22, 2021 Started to install the loader I bought and did not like the way it was mounted or made.here is what I have done so far. 3x3 tube for the uprights and they will be hydraulic tanks,4 inch channel bolted to the frame. 2 1 Share this post Link to post Share on other sites
953 nut 57,428 #2 Posted March 22, 2021 49 minutes ago, ricksrj58 said: 4 inch channel bolted to the frame. You need a substantial sub-frame that will transfer the weight and forces to your axles. Bolting the crossmember to the frame will result in a bent frame. I will take some pictures of the subframe on my GT-14 tomorrow and post them. 6 Share this post Link to post Share on other sites
roadapples 6,983 #3 Posted March 22, 2021 (edited) Won't that be a lot of strain on the tractor frame? All I've seen had a sub frame. Just wondering... Richard types faster than me Edited March 22, 2021 by roadapples 3 2 Share this post Link to post Share on other sites
Pullstart 64,338 #4 Posted March 22, 2021 I’d say that’s a good start, but far from strong enough as Richard and Jay have mentioned. Keep going! 2 Share this post Link to post Share on other sites
TJ5208 1,824 #5 Posted March 22, 2021 You lift a load it bend completely down that will be something nice job and good luck Share this post Link to post Share on other sites
Tractorhead 9,087 #6 Posted March 22, 2021 I love constructions, even constructions of FEL‘s because i built 2 FEL myself, but please accept the advices you get from the fellas here and work urgently with a Subframe. I built my first FEL on a 212 - yes a Sheet Metal machine and nobody believes this would work. It did, but it also give me a heavy wear on the Frontaxle, because i didn‘t work with a Counterweight. for simple and easy tasks it may be useful, but if you have a loader, you be use it as a loader. - trust me, i know where i‘m talking about. I doubt the frame itself will bent that fast depending on used load, but the Screws they hold your Rearaxle together with the Frame will quit quickly. This tractas are definitely well built, but they be not built for such on top loads. you also bring the load 2:1 or maybe more directly to your Frontaxle. That means if you pick up a load with 30 Kilos, 60 Kilos will last on your Frontaxle. The result is a quick wear on frontaxle followed by hard steering because of the wear and load. With a Subframe you be able to reduce that load on the front axle, especially when it go behind the rearaxle with a Counterweight box, so you be able to reduce a lot of the load from the frontaxle more to the Rear. this loadbalancing can be made so much easier and you have more fun with it. 1 Share this post Link to post Share on other sites
953 nut 57,428 #7 Posted March 22, 2021 21 hours ago, 953 nut said: I will take some pictures of the subframe on my GT-14 tomorrow and post them. The transmission is out of my GT-14 so you can get a good look at the rear of the subframe. The rear portion of the subframe attaches to both rear axle housings and the front of the frame. The front portion of the subframe attaches to the front of the frame and is tied into the uprights of the loader. The portion of the frame that is parallel to the frame are angle iron 2.5 X 2 -1/4" thick (heavier than your 1054's frame. The cross beam is 3 X 2.5 - !/4 wall tubing. Your 1054 frame has four holes (two on each side) that would be ideal for mounting the front portion. The forces applied to the subframe are transferred to the front and rear axles without compromising the integrity of the tractor frame. How you attach your loader is up to you, we are just attempting to save you from having a twisted frame. 1 Share this post Link to post Share on other sites
ricksrj58 273 #8 Posted March 23, 2021 Thank you for confirming my thoughts,we figured we might have to connect it to the rear axle and I did start to fab up a front mount already. The pics are great,thank you. 1 Share this post Link to post Share on other sites
ricksrj58 273 #9 Posted April 1, 2021 Have not made any real progress yet other than making tabs and pins for the loader arms and cylinders 1 Share this post Link to post Share on other sites
ricksrj58 273 #10 Posted April 1, 2021 I am thinking because my tractor has only the original hitch,I will extend the subframe back past the tranny and set the weight box on it and also clamp it to the axle tubes with the sub frame clamps. 2 Share this post Link to post Share on other sites
