Similar Content
By KC9KAS
A friend has a D-160 and it stopped moving.
He said the engine coupling will spin but not the pump.
I told him the pump splines were probably shot, but he is recovering from surgery and hasn't been able to check into it.
Does anyone have a pump for sale with good splines and/or the coupling (female) spline?
Thank you in advance.
By Team70R
Waiting on the eBay electric fuel pump to show up for the C165. Only thing I'm not sure about is what to do with the old mechanical one. Do I just leave it in place or do I need to make a cover plate with the a gasket and remove it?
By sodbuster
I need a replacement pump for my ark 700 loader. pump now is a Cessna 8nc-26-ds. . searched for cross reference with no luck. need gallons per minute.thanks
By RainbowMeatballs
Following the death of my 520H's fuel pump, I bought a low-pressure electric pump. The problem is, I know almost nothing about electrical systems, and I am wondering where to hook up the pump. I am thinking that I could use the pink line coming from the A terminal, but I'm not absolutely sure. I was also wondering if I could attach it with ring hooks to one of the meters. (piggy-backing) I'm not sure of the amps this uses, but it seems to have 14 gauge wire. To be safe, would adding a 20 amp fuse screw up the meters if I switched it in the place the 10 amp? This is the pump: Amazon
I have an inline fuse holder if my ideas have been completely wrong.
