Gregor 4,847 #1 Posted March 19, 2021 There is no greater bond on earth, than that of a mother for her off-spring. EXCEPT ! 2 buckets stuck together 1 17 Share this post Link to post Share on other sites
ebinmaine 69,838 #2 Posted March 19, 2021 The man speaks the truth. 2 Share this post Link to post Share on other sites
squonk 41,983 #4 Posted March 19, 2021 Throw them on the ground so the side hits. Might spring em. If that doesn't work, get out the hose! 3 Share this post Link to post Share on other sites
Achto 28,249 #5 Posted March 19, 2021 If you have an air compressor, grab a blow gun and point it at the seam where they meet. It will force air into the lower bucket & they will come right apart. Works every time!! 4 1 Share this post Link to post Share on other sites
haydendavid380 759 #6 Posted March 19, 2021 The local farm store has a 10% everything you can fit in a bucket sale quite often. There's a stack in the corner of probably no less than a dozen. I just leave the most recent one out of the stack and never have to fight it apart 😆 Share this post Link to post Share on other sites
stevasaurus 22,973 #7 Posted March 19, 2021 When I put them together anymore, I stand a wooden shim up on the side between the 2 buckets. 1 Share this post Link to post Share on other sites
squonk 41,983 #8 Posted March 19, 2021 1 hour ago, Achto said: If you have an air compressor, grab a blow gun and point it at the seam where they meet. It will force air into the lower bucket & they will come right apart. Works every time!! Even more funner, Empty antifreeze jug with a cap. Drill a hole in the cap and install a male air hose fitting screw the cap on the jug. Connect an air hose to the fitting and place the jug under @WHX24's work bench. Wait for said @WHX24 to start working on his transmission on the bench. Plug the opposite end of the hose into the shop air line and stand back. Wait for the hi-jinx to start! For even more hilarity add about a quart of water to the jug! 5 Share this post Link to post Share on other sites
