JAinVA
Carburetor
JAinVA
I am looking for insight from you guys. I have bought a couple of aftermarket carbs for my Kohler m12s. The originals were not rebuildable. I have not had much luck and am now looking at the units from I save tractors Any comments and opinions are welcome. Thanks in advance
elcamino/wheelhorse
I have bought 2 carbs from I save Tractors. One for a 310 and one for a 416 . Both worked great . No problems.
JAinVA
Thanks Jim!  That's what I needed to know.
ebinmaine
I haven't bought anything from Norman yet but he seems like a decent guy.
I've heard concerns he may have grown to big too fast and can't offer the time he once did to customers.
Far as carbs go I only have experience with older K Series.
I've had several junk aftermarket carbs on 12 to 16 HP engines.
I got one for a K341 specifically sorted out on the site for the larger engines. When I got it I tried at least 3 times to get it going. Failed for different reasons.
I finally got a used one from Lincoln at A to Z tractor and rebuilt that.
Problem free since.
I discovered that the aftermarket carb was a smaller bore than original by a long shot.
Double check that Norman.
I won't be buying another cheap carb.
Again..... All K Series experiences.
Gregor
I will agree with that.
That being said, I have bought several China carbs from him, and they all were adequate
Like @ebinmainesaid, if you can find a decent re-buldable carb. Thats the way to go.
Pullstart
I haven’t gotten a carb from isavetractors but I have received a few error free and on time orders from him just fine.  I say he’s a reputable parts source :handgestures-thumbupright:
Ed Kennell
I used one of his on a K.   It worked great right out of the box.
peter lena
JAINVA,  bought a carb from I SAVE TRACTORS , have not touched it , since starting it up ! ,really no adjustments needed and continues to run without any issues, been a couple of years . regularly use  STA -BIL  in all my fuel with instant starts . pete
pfrederi
I used one of his on a K-341 never could get it to run right.  Rebuilt the old one instead.
ebinmaine
Just out of curiosity did you ever happen to check the bore size on that carb?
pfrederi
No
Gregor
If I have nothing, I have carburetors. I am assuming by bore, you mean the size of the throat. If thats not right, well, I'm a little slow ya know.
All of the new carbs are from isvetractors. Who I believe is still a good place to do business with.
20210317_090418.jpg.d8bc4613d18595a97dfbd4d8853aa6ba.jpgCarb on the left (Kohler) measures,
1.20". The 2 on the right, 1.17"  These were ordered for a K321.
These carbs are for a K181. Carb on left, (Kohler, as far as I know) .83".   Carb on right, .82"
ebinmaine
IMHO those sizes are close enough.
I don't remember the sizes or the differences but when I say it's substantial it was probably close to 1/4" smaller in throat diameter.
I would have felt reasonable about putting it on a 10 horse. Possibly a 12. That would have been a stretch.
Howie
It's just a restrictor plate! :rolleyes:
Gregor
Good for 1 acre lawns and larger. :auto-nascar:
Mirage276
I just got a #30 from isavetractors for my K341 and everything seems fine, ran well and the engine idled better than it ever has before. I was trying to rebuild/clean mine but snapped 3 of the 4 screws on the throttle/choke shafts and needed something quick so I can get to mowing.  Both the stock throttle and choke blades fit into the replacement so if its sized differently its marginal on the carb I got, but I did not measure the bores.
ebinmaine
If they sold you a clearly marked #30 it should be the same.
Did you keep the old body?
You probably know it by now.... Those screws are either locktite held in, staked in, or both. They need to be ground very carefully to be removed.
Do you have plans for the old carb now?
Mirage276
Yea learned that the hard way, never torn down a carb before. Have dealt with stubborn throttle body screws before but I wasn't even thinking about it when I jumped in. Used a hacksaw blade to finish them off and get it all apart.
I will probably finish rebuilding it and keep it as a spare if I can get ahold of some shafts or get someone to drill them out for me.
ebinmaine
Post a pic or two of what you have. I've used a dremel type tool to get them out.
Gregor
FYI  The shafts from the carb you jsut bought will fit, if you would rather have the old carb.
haydendavid380
I have one on a K181. Works fine.
