Countdown To Christmas!
Oldskool
A Horse named Hiram
Maxwell-8
So hoping this will work great!
Oldskool
46 minutes ago, ebinmaine said:
REALLY looking forward to the testing...
Me too.
Oldskool
You and me both lol
Handy Don
54 minutes ago, Oldskool said:
but have you ever been told something wont work? Then you tried doing it anyways just to see first hand?
Sometimes you win, right?
Just last week was looking at a tractor and the seemingly competent owner told me the engine was non-functional--took him at his word and he accepted my offer based on the rest.
At home, curious after unloading it, I gently pulled the engine through a few turns to check for compression and any obvious internal issues and it seemed ok. Unfroze the choke cable then set it and the throttle, switched the key to "Run", and it started on the third pull.
With a smile on my face, I shut it off quickly and put it aside until I can go through the carb, oil, plug, belts, transmission, etc.
I won't bore all y'all with the number of times I've proved to myself that the naysayers were, in fact, correct.
  • Excellent 5
Oldskool
We all learn from our mistakes.🤔 Half the fun is finding out. 🤣
  • Excellent 2
Oldskool
At this point I dont even care if they work. They look cool
  • Excellent 3
  • Haha 4
ebinmaine
I'll give ya that.
Imagine if they slowed the ride down too??
  • Haha 3
Oldskool
I'll give ya that.
We all may find out today. I have lug nuts coming from 45 miles away. I will have them in my grubby paws in an hour. I just have to find a replacement gas tank in that hour.
  • Excellent 2
Maxwell-8
Is it independent breaking? When you are stuck, one wheel spinning, pull the brake on that side. vrooom :auto-layrubber:right out of the hole.
Oldskool
It is supposed to be, yes. It's to aid in steering on uneven ground. Also when pulling and your front wheels are just in the air enough you cant steer.
  • Excellent 4
Stormin
I think fiddle brakes are a great idea. Are you going to fit a bar to join the pedals for normal use? You don't want to stamp on the brakes in a hurry and turn left/right unintentionally. Been there. Done that.
  • Haha 4
Oldskool
Im actually still utilizing the original brake set up as well
Thor27
Are you using a tapered lug nut?
PS   I REALLY like this tractor
Edited by Thor27
Oldskool
Yes I am.  I tapered the holes in the wheels to accept them..
PS.   Thanks.
elcamino/wheelhorse
Now I have to go back to the beginning and see pictures of the brake build. Gives me something to do in the heat down here.
  • Haha 1
Oldskool
There arent any posted yet.
elcamino/wheelhorse
Please post when you have time.
  • Excellent 2
Oldskool
Here is a few
Oldskool
The lug nuts have arrived. I have to go borrow the fuel tank off my tiller to get a ride on ole Hiram
  • Excellent 3
  • Heart 3
Oldskool
Well there will be a video posted very soon.
SylvanLakeWH
Beautiful job!!!
:bow-blue:
Oldskool
15 minutes ago, SylvanLakeWH said:
Beautiful job!!!
:bow-blue:
Thank you. I had alot of fun with this build.
  • Similar Content
    • Oldskool
      By Oldskool
      Hey guys I have been given a box of these flap wheels.
      5.25" x 1.5" with a 1" arbor hole.
      I instantly thought great I can put one on my bench grinder.
      Nope!    Not that simple.
      The arbor size is different, and it's to wide to fit inside the the guard.
      I thought of removing the guard but would like to have it there.
      I guess I could make an arbor adapter and a spacer for the guard,and a new tool rest,etc. More time involved then first thought.
      Does anyone use these, and if so what do you have it on?
    • c100rider
      By c100rider
      Hello fellas. I bought this 211-3 tractor. I have no clue how this mower deck comes off. I need to fix some areas on the deck, as well as replace a clutch cable. I can't seem to find pictures of a complete deck for this model as it should be. Need help.
    • Oldskool
      By Oldskool
      Let's see your view from your workplace "window". I know some are driving truck,or tractor, work in shops/offices or outdoors. What is it that surrounds you during your work day?
    • Oldskool
      By Oldskool
      I've had some stuff laying around for a while now. I've had some ideas kicking around my head for a while as well.
      Well they met each other a few days ago.
      This is going to be a camp buggy of sorts.
      Like any of my other builds I would appreciate any input anyone want to donate.
      The base is an 1982-88 Yamaha G1 golf cart.
    • Oldskool
      By Oldskool
      Can anyone ID this?
