Oldskool
A Horse named Hiram
WHX??
Ouch...
ebinmaine
AAAGGGGHHHHHH
Pullstart
I’m nowhere near Maine.  Eyes. Watering.
  • Haha 3
Tractorhead
I knew nobody likes smat- ass but how about protective googles ?
Oldskool
I have them and use them, plus I have eyeglasses. I had it happen once years ago. Didnt like it. This was an unplanned last cut that went totally wrong. Wrong place wrong time.
  • Sad 2
Oldskool
I'm a firm believer in safety first. I do get bulling around at times and walk the line a bit. Along with that I'm about as graceful as a Gazellephant.
  • Haha 3
Pullstart
we must be cuzzies...  I have a lifetime membership to the bumps and bruises club!
  • Haha 3
Oldskool
Oh I think I own stock in that club
Handy Don
On 3/19/2021 at 5:28 PM, Oldskool said:
Maybe I should repower with this? Just picked this up today.
Now that you explain, I do remember seeing one of these in action in a museum demo somewhere. They had it outside on the lawn washing dishrags. Thanks for posting it.
Oldskool
I need info on the clutch/brake pedal return spring. Size and fastening location would be great. I'm gearing up for a 3 day weekend ahead. I hope to get alot done.
ebinmaine
Keeping it as a single pedal it'll be like Trina's 867 Pigpen.
Gimme a few minutes. I'll send some pics.
Oldskool
Always working with as much on hand as possible i had to make a shaft adapter for the pulley. The engine I chose had a stepped shaft.
Oldskool
The belt is on. I hope it correct. Also working on a parking brake. I think I'm making headway.
  • Like 5
  • Confused 1
Pullstart
The belt looks great!  Is it fabric/Kevlar coated?  The parking brakes looks functional, but the spring doesn’t seem “right” for some reason.  Maybe it’s needed because of the excess weight of the rod on top?
Edited by pullstart
Oldskool
The spring it set to auto engage the parking brake. I can clutch  before it auto sets. After looking at it I probably should have it auto release instead. Maybe that's why the spring looks wrong?
Oldskool
There should be a tension spring on it somewhere. The only thing holding it tight is the brake spring at the moment
ebinmaine
That's what you want right there
Pullstart
there should be a spring from the rib on the top of the left axle housing to the brake/clutch rod.  That’ll give you belt tension.
Oldskool
If someone was going to reline a brake band what's the best way to do it.? I've seen where people have used everthing from actual woven brake material to leather. Mcmaster offers a molded liner and woven. Has anyone had any experience with the molded? I have also seen where people have used all differant types of adhesives. Anything from Gorilla Glue to Liquid nails. I would like to hear some input. Good and bad.
Gregor
I don't know anything about the lining material, but I have never had good luck with Gorilla Glue. It may be good for porous material, if you have a few months to let it set up, but it's never worked good for me. Others may have had better luck with it.
Oldskool
I cant say I have either. Definitely bottom on my list.
ebinmaine
I bought a roll of brake lining material from McMaster-Carr.
I attach it width clear silicone and about 8 or 10 zip ties. Several applications including the Cinnamon Horse C160 which gets worked pretty good.
No issues.
Highly recommend going that route.
Gimme a width and length. I'll see what the stuff I have here is for size.
SylvanLakeWH
Vendor on this site:
Oldskool
How did you utilize the zip ties?
ebinmaine
I had Trina hold the lining in place and ziptied her hand to it.
  • Haha 3
  • Heart 1
  • Similar Content
    • c100rider
      By c100rider
      Hello fellas. I bought this 211-3 tractor. I have no clue how this mower deck comes off. I need to fix some areas on the deck, as well as replace a clutch cable. I can't seem to find pictures of a complete deck for this model as it should be. Need help.
    • Oldskool
      By Oldskool
      Let's see your view from your workplace "window". I know some are driving truck,or tractor, work in shops/offices or outdoors. What is it that surrounds you during your work day?
    • Oldskool
      By Oldskool
      I've had some stuff laying around for a while now. I've had some ideas kicking around my head for a while as well.
      Well they met each other a few days ago.
      This is going to be a camp buggy of sorts.
      Like any of my other builds I would appreciate any input anyone want to donate.
      The base is an 1982-88 Yamaha G1 golf cart.
    • Oldskool
      By Oldskool
      Can anyone ID this?
    • Oldskool
      By Oldskool
      I've wanted to do this type of project for a while now. So here we go. The name was given by @wallfish. It will be called "The Yeti".  It will be painted and badged in a military theme. The front axle is in progress now.
