Dan.gerous 2,696 #1 Posted March 15, 2021 Thanks to @Keith of kent for some extra parts to add to my growing collection of Wheelhorse bits and bobs in the garage. Its like Christmas! 2 4 Share this post Link to post Share on other sites
Dan.gerous 2,696 #2 Posted March 15, 2021 Does anybody know what sort of hubs I can get for these - probably something non wheelhorse 5 stud, as original stuff would be hard to source here. Could make a very cool trailer. I have no idea what dimensions you have to get to match up a hub. Thoughts.....? Share this post Link to post Share on other sites
Pullstart 62,921 #3 Posted March 15, 2021 (edited) 16 minutes ago, Dan.gerous said: Does anybody know what sort of hubs I can get for these - probably something non wheelhorse 5 stud, as original stuff would be hard to source here. Could make a very cool trailer. I have no idea what dimensions you have to get to match up a hub. Thoughts.....? It seems I read a Toyota Camry hub will fit? Might want to verify their pattern... Edited March 15, 2021 by pullstart 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,053 #4 Posted March 15, 2021 5 stud with a 4-1/2" bolt circle. Toyota listed as 114.3mm bolt circle same thing. Light duty trailer axles in North America use the same size. I have 14" or 15" wheels off a large 1980's Buick or Oldsmobile front wheel drive mounted backwards on a WH and look stock except for the diameter. Garry 1 2 Share this post Link to post Share on other sites
Pullstart 62,921 #5 Posted March 15, 2021 18 minutes ago, gwest_ca said: 5 stud with a 4-1/2" bolt circle. Toyota listed as 114.3mm bolt circle same thing. Light duty trailer axles in North America use the same size. I have 14" or 15" wheels off a large 1980's Buick or Oldsmobile front wheel drive mounted backwards on a WH and look stock except for the diameter. Garry What model WH and what tires did you mount up? Share this post Link to post Share on other sites
Lee1977 6,673 #6 Posted March 15, 2021 Old full size Ford, Rambler were 5 on 4 1/2" circle The Rambler were machined flat on the back side with 4 mounting bolts. 1 Share this post Link to post Share on other sites
