ebinmaine 69,842 #1 Posted March 14, 2021 I've seen a piece of plastic in a couple tractors. Mostly disintegrated. Is there a particular thing or substance you put between the two? Share this post Link to post Share on other sites
Lee1977 6,937 #2 Posted March 14, 2021 (edited) My C-120 didn't have a metal gas tank but it did have a clear plastic piece between the tank and dash. It fit up under back of the cast dash. Edited March 14, 2021 by Lee1977 1 Share this post Link to post Share on other sites
roadapples 6,983 #3 Posted March 14, 2021 I thought that was to help keep dirt out... 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,187 #4 Posted March 15, 2021 The 1977 C-Series used a plastic tank. Can see why they are still available from Toro at $124.08 at Parts Tree. Garry 2 1 1 Share this post Link to post Share on other sites
Lee1977 6,937 #5 Posted March 15, 2021 The $124.08 is the reason they are still available. They might have sold them all at a reasonable price of $4.08. 3 2 Share this post Link to post Share on other sites
Achto 28,249 #6 Posted March 15, 2021 2 hours ago, ebinmaine said: I've seen a piece of plastic in a couple tractors. Mostly disintegrated. Is there a particular thing or substance you put between the two? Are you talking about the piece of plastic that is looped over the terminals on the switch?? I have cut a new one out of a milk jug to replace a missing one. 4 2 Share this post Link to post Share on other sites
Shynon 7,474 #7 Posted March 15, 2021 3 minutes ago, Achto said: Are you talking about the piece of plastic that is looped over the terminals on the switch?? I have cut a new one out of a milk jug to replace a missing one. I cut one out of a coffee container 3 Share this post Link to post Share on other sites
ebinmaine 69,842 #8 Posted March 15, 2021 6 hours ago, Achto said: Are you talking about the piece of plastic that is looped over the terminals on the switch?? I have cut a new one out of a milk jug to replace a missing one. Yessir. Do you have a pic or diagram? We don't even have anything to go by here. 1 Share this post Link to post Share on other sites
Achto 28,249 #9 Posted March 15, 2021 1 hour ago, ebinmaine said: Yessir. Do you have a pic or diagram? I'll get you a pic with measurement's tonight. 1 Share this post Link to post Share on other sites
ebinmaine 69,842 #10 Posted March 15, 2021 29 minutes ago, Achto said: I'll get you a pic with measurement's tonight. You're all right Dan. I don't care what Uncle Jim says about you. 1 Share this post Link to post Share on other sites
Retired Wrencher 5,592 #11 Posted March 15, 2021 25 minutes ago, ebinmaine said: You're all right Dan. I don't care what Uncle Jim says about you. Eric I know that all the start /gens that I had a loop around the switch to prevent spark and gas. 2 Share this post Link to post Share on other sites
Gregor 4,847 #12 Posted March 15, 2021 Fish Paper Electrical insulating fiber paper. It will bend and mold to your needs. VERY tough stuff. Available at McMaster Carr 1 Share this post Link to post Share on other sites
ebinmaine 69,842 #13 Posted March 15, 2021 17 minutes ago, Retierd Wrencher said: Eric I know that all the start /gens that I had a loop around the switch to prevent spark and gas. Yeah that's the one. Just not sure where it goes to and from... 1 Share this post Link to post Share on other sites
squonk 41,983 #14 Posted March 15, 2021 (edited) 23 minutes ago, ebinmaine said: Yeah that's the one. Just not sure where it goes to and from... There are 2 holes drilled in it. You form a loop,line up the holes and the post of the switch goes through the holes. Then the switch post goes through the dash. Kind of a PITA to get it all in there. Edited March 15, 2021 by squonk 1 Share this post Link to post Share on other sites
ebinmaine 69,842 #15 Posted March 15, 2021 5 minutes ago, squonk said: There are 2 holes drilled in it. You form a loop,line up the holes and the post of the switch goes through the holes. Then the switch post goes through the dash. Kind of a PITA to get it all in there. so it wraps all the way around the switch and has approximately 5/8 diameter holes in it? Share this post Link to post Share on other sites
squonk 41,983 #16 Posted March 15, 2021 1 minute ago, ebinmaine said: so it wraps all the way around the switch and has approximately 5/8 diameter holes in it? Yeppers 1 Share this post Link to post Share on other sites
ebinmaine 69,842 #17 Posted March 15, 2021 10 hours ago, Shynon said: I cut one out of a coffee container Tom or @Achto Dan... Any particular brand of coffee or milk? 1 Share this post Link to post Share on other sites
squonk 41,983 #18 Posted March 15, 2021 22 minutes ago, ebinmaine said: Tom or @Achto Dan... Any particular brand of coffee or milk? I would think "Chock Full of Nuts would be a fave! 3 Share this post Link to post Share on other sites
Achto 28,249 #19 Posted March 15, 2021 (edited) 27 minutes ago, ebinmaine said: ny particular brand of coffee or milk? I used a Kwik Trip milk jug, If you wanna stick with that brand I'll have to send you one. KT's are mostly a Wisconsin thing. In this case it's more about the container than the contents. Need a nice pliable container that is easy to work with and won't crack. Edited March 15, 2021 by Achto 1 Share this post Link to post Share on other sites
Gregor 4,847 #20 Posted March 15, 2021 47 minutes ago, ebinmaine said: Tom or @Achto Dan... Any particular brand of coffee or milk? Skim milk. Unless you need the weight for plowing, then whole milk. 1 1 Share this post Link to post Share on other sites
lynnmor 7,502 #21 Posted March 15, 2021 Would something like this work? Other kinds are available. Share this post Link to post Share on other sites
Retired Wrencher 5,592 #22 Posted March 16, 2021 23 hours ago, ebinmaine said: so it wraps all the way around the switch and has approximately 5/8 diameter holes in it? Yes Eric it is a wrap around type. Then is held down by the console with the big washer and nut. 1 Share this post Link to post Share on other sites
ebinmaine 69,842 #23 Posted March 16, 2021 20 hours ago, lynnmor said: Would something like this work? Other kinds are available. Tried to look at that link and it only got me to the front page of McMaster Share this post Link to post Share on other sites
squonk 41,983 #24 Posted March 16, 2021 Click on the picture of the plastic material. Options should open up. 1 Share this post Link to post Share on other sites
lynnmor 7,502 #25 Posted March 16, 2021 1 hour ago, ebinmaine said: Tried to look at that link and it only got me to the front page of McMaster I'm having problems with the McMaster website now. When I posted it, there was a 3/64" option for an easy to form 3/64" clear plastic, my guess is that they are in the middle of an update. I have purchased plastic from them that bent easily into a Z shape when heated and hardened when cooled. 1 Share this post Link to post Share on other sites
