jakester
unknown electrical componant
jakester
hello all I'm a new owner of a 312-8 tractor, have starting problems, came across a very small, what I believe is a relay between the battery and the dash,its about 2/3rd size of a cube of sugar silver on the outside blue on top with a hole bout the size of a pea, theres 6 pins with wires connected to it on the bottom do not know what this is any thoughts? I cannot determine the exact year of this machine for there is no tag anywhere only tag on engine kohler magnum md #m12s   ser# 170370459  spec#  471527  I figure its mid to late 80s to early 90s. of all the wiring diagrams ive looked at it does not show any thing like what I just described also can that little circuit board be removed that's like a test point for idiot lights? any help would be appreciated  jeff
gwest_ca
Welcome to the forum.
There is one number missing in your engine serial number but if the first 2 digits are 17 Kohler made your engine in 1987.
That should make your tractor
1987 312-8 model 21-12K804 or
1988 312-8 model 21-12K805
Sounds like you are describing the early style of low oil relay with a metal cover. Later on a replacement would be smaller and have a black plastic cover.
Yes the circuit board can be removed and it will have no affect on the rest of the wiring or how the tractor operates.
If the board and lights work and the tractor will not start it should indicate which circuit is preventing the start.
If you need to remove the low oil float switch from the base of the engine there are special instructions on how to do it without damaging the switch. This switch controls the starter - low oil and the starter will not run.
Garry
Ed Kennell
:text-welcomeconfetti: to the :rs: Jake.       Looks like Garry has you covered.         The tractor ID tag should be on the left side of the  fender pan under the seat.
Tell us a little history of yourself and the 312-8.             We like   :text-coolphotos:
953 nut
:WRS:
As Garry has said you have a 1987 model.  What color are the wires coming from the item you are looking at? We don't want to change or remove any components until we figure out what is working and what isn't
Please be a little more specific when you say you are having starting problems. Was this problem already existing when you bought the 312 or is it a new problem? When you turn the key to start what dose or doesn't happen? Is the engine oil level up to the full mark? Is the battery fully charged? Presuming the battery is charged if you take a screwdriver and connect the two large terminals of the solenoid dose the starter turn over? Presuming the starter turns over take a small wire from the battery "+" terminal to the small solenoid terminal that has a blue wire connected to it, dose the starter turn over?
SylvanLakeWH
jakester
bought this from a guy few weeks ago, its in very nice shape, the engine shroud is half off cause he was putting a new coil on but never finished, cut fuel line for it had water in tank from sitting outside for a while, engine cranks when jump battery to starter, all wiring looks intact except for that little thing which one wire loose from it, getting frustrated trying to figure out which model I have there is nothing anywhere which tells me what it is. only the decal on the engine. been to cold here to mess around with it much I live in south east mich. as for me I am 62, retired  and I bought this soley to plow snow for the toro snowblower is to hard on my hands from the vibration, being I have carpel tunnel have a plow lined up for it, use to run an old sears tractor my dad had to keep driveway clear back in 60s and 70s, that thing was built like a tank, had an 8 horse Tecumseh that would not quit. I would like to upload pix of that thing I was telling you about, but my smart phone savvy is not that good, will have son or daughter help me with that!! thanks for any help   jeff
  • Thanks 1
gwest_ca
Wiring diagram same for 1987-88
Garry
The Tuul Crib
:text-welcomeconfetti:T😎 :rs:
:wwp: !
953 nut
I feel your pain, literally. I had the carpel tunnel release surgery done a couple years back, made a big difference in my lifestyle.
When your weather improves and you are ready to dive into this project we are here to help. Meanwhile you can surf threads on here about electrical repairs and other issues.
jakester
as for the picture of the solenoid there is two large terminals on top and one small one  below the large one on the right if your looking at it like the picture above. how many safety switches are on this model?
Pullstart
:text-welcomeconfetti: from Mid-West Michigan!  You’ll enjoy this for snow duty, even if we don’t have any until later in the year!  I know, likely wishful thinking over here... but I’m ready for Tractor Show Season!
Tractorhead
:text-welcomeconfetti:  to  :rs:
953 nut
There are three safety switches on your tractor. The clutch switch will prevent the starter from turning over if then clutch is not depressed. The seat switch will stop the engine from running if the operator is not in the seat while the PTO is on. The PTO Switch has two functions, it prevents the starter from turning if the PTO is on and it stop the engine if it is on and no operator in the seat.
There is also a low oil level switch in the engine which operates that silver relay, if the oil level is low it will activate the relay and prevent the starter from turning.
This drawing is from our electrical demystification guide and shows the wiring with all switches in the correct position for starting.
Hope this is helpful.
  • Similar Content
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • BrianKoch
      By BrianKoch
      Hello gentleman,
      Problem: will not crank on its own, will crank with jump box—but still not fire
      Recent things I did prior to this issue: cleaned fuel filter, replaced battery cables, replaced cable from ignition to starter
      I have my test light out and am probing around.
      There is no power at ignition/magneto wire or the ignition/starter wire
      There is power everywhere else
    • Jeff-C175
      By Jeff-C175
      Detailed wiring from the Demystification Guide #492-4509
      4 pages 1.4MB Color
      p7-67 to p7-70
      Onan powered
      1989 416-8 model 31-16O801
    • trident
      By trident
      Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
    • grasscuts
      By grasscuts
      Hi, here's what happened. I changed out 9 pin moles plug...had issues tracter quit running and changed the plugs while I was at it....got plugs from auto store cross reference to ngk they said it was the same heat range and I check electrod  length with calipers ,same...tracter started right up and ran great for about 10 min. And started back firing and quit.....going to check it out tonite anybody have an idea?
