The Tuul Crib
What deck do these blades fit on?
The Tuul Crib
Looking through my parts I run across this
set of three blades still in plastic. But I'm not sure what they fit on anybody know by the number?
oldlineman
looks like a 42 in deck
The Tuul Crib
Well they're a little shorter than what a 42 inch deck calls for. I am looking to order some blades for my 42 inch rear discharge and calls for a 14 1/2 inch blade. these are 13 7/8. :confusion-confused:
gwest_ca
May not fit them all if any of these models shared a illustrated part list. That is what happened for the 1990 models.
These used on 612-Z, 616-Z and 620-Z
117192 also replaced 116207 but do not know what those fit.
Garry
The Tuul Crib
Garry
Thanx Garry!!
Lee1977
I went down and turned my 42" deck over and measures that is what is on it. The blade are worn and measure around 13 3/4".
It don't have a tag as the 42 always rust out at the height adjustment. It came with my 1989 520-H has the bar or tube reinforcement around the front.
Edited by Lee1977
oldlineman
Yea sorry I knew 42" side and rear (i have both) required different size blades but didn't know off hand witch way they were. As always Garry came to the rescue!
