Myron 1 #1 Posted March 12, 2021 I have WH 516H ID 34-160E01 I can't push the machine even with belt of the hydro . Is there a fix for this problem ? Myron 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,095 #2 Posted March 12, 2021 Rewrote your model number 31-16OE01 This model uses the 700 Eaton transmission. Here is the operator manual and more in case you do not have them. I have no hydro experience. Share this post Link to post Share on other sites
JAinVA 4,620 #3 Posted March 12, 2021 (edited) I bought a tractor with the Eaton 700 transaxle some time back and you could not push or pull it because the rear tires wouldn't turn Quite by accident I pushed the motion control lever full forward and the tractor would roll. Give it a try. Edited March 13, 2021 by JAinVA 2 Share this post Link to post Share on other sites
Ed Kennell 38,634 #4 Posted March 12, 2021 I only had one 700 and it would not roll. Do not ever tow or push with another machine. You could damage the hydro. 1 Share this post Link to post Share on other sites
stevasaurus 22,862 #5 Posted March 12, 2021 @Myron , I edited your thread title to let members know what the thread was about. You want to do that when you start a thread. Welcome to Red Square. 2 Share this post Link to post Share on other sites
Handy Don 12,457 #6 Posted March 13, 2021 The 700 I ran was also stubborn about rolling. As noted, experiment with different positions of the motion control lever. With mine, mostly forward worked best for pushing in both directions but YMMV. Good luck. Share this post Link to post Share on other sites
grinchsr 634 #7 Posted March 13, 2021 When I bought mine it was not running so I used car dollies to move it around 1 Share this post Link to post Share on other sites
953 nut 55,767 #9 Posted March 13, 2021 The service manual below may be helpful. Be sure the belt tensioner (part 49) is down and the motion control lever is forward when pushing. go very slowly. Share this post Link to post Share on other sites
Skibumpis 0 #10 Posted July 25, 2021 Exactly what I have been looking for as far as trying to move a locked Eaton 700 Very frustrating, now if I could only find out why it won't turnover! Share this post Link to post Share on other sites
Gregor 4,847 #11 Posted July 25, 2021 On 3/12/2021 at 2:22 PM, Myron said: I have WH 516H ID 34-160E01 I can't push the machine even with belt of the hydro . Is there a fix for this problem ? Myron Can you spin the trans drive pulley by hand, with the belt off? Share this post Link to post Share on other sites
Ed Kennell 38,634 #12 Posted July 25, 2021 8 hours ago, Skibumpis said: Exactly what I have been looking for as far as trying to move a locked Eaton 700 Very frustrating, now if I could only find out why it won't turnover! to the It would be best to start a new thread to get your questions answered. If you post the model number, we can get the wiring diagram for your tractor and help you get it running. Share this post Link to post Share on other sites
Tuneup 1,433 #13 Posted July 31, 2021 Howdy Ski, My 516H is impossible to move with the belt engaged and difficult with it disengaged. You'll want to make sure that disengaged is actually so - stops rubbing on the pulley. If I have just run it, mowing or whatever, it pushes much easier. The Eaton is a bit worn and runs well on 15W-50. Share this post Link to post Share on other sites
