The Tuul Crib 7,336 #1 Posted March 11, 2021 (edited) This is my backyard hillside after the last big rain we had. It's wet weather spring when it rains it comes out of the side of the hill. Hass to be a cave in there somewhere! IMG_1075.MOV Edited March 11, 2021 by The Tuul Crib 1 Share this post Link to post Share on other sites
AMC RULES 37,130 #2 Posted March 11, 2021 storage! 1 1 Share this post Link to post Share on other sites
Jeff-C175 7,199 #3 Posted March 11, 2021 All I get after the lengthy download is this, with audio that sounds like rushing water: 1 Share this post Link to post Share on other sites
Ed Kennell 38,028 #4 Posted March 11, 2021 water running only no video. Share this post Link to post Share on other sites
stevasaurus 22,711 #5 Posted March 11, 2021 Randy, can you up-load to You-Tube and the post the link. That vid in that format takes up a lot of space on this site. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,336 #6 Posted March 11, 2021 52 minutes ago, stevasaurus said: Randy, can you up-load to You-Tube and the post the link. That vid in that format takes up a lot of space on this site. Thanks Steve I'll give it a try! Share this post Link to post Share on other sites
ebinmaine 67,309 #7 Posted March 11, 2021 3 hours ago, The Tuul Crib said: Thanks Steve I'll give it a try! It's easy enough that even I can do it. Share this post Link to post Share on other sites
8ntruck 6,991 #8 Posted March 11, 2021 I've got a spot on my 20 acres just outside Bowling Green, Ky. where water comes out of the side of the hill. Could be we are both hooked up to the Mammoth Cave system? 1 Share this post Link to post Share on other sites
The Tuul Crib 7,336 #9 Posted March 12, 2021 1 hour ago, 8ntruck said: I've got a spot on my 20 acres just outside Bowling Green, Ky. where water comes out of the side of the hill. Could be we are both hooked up to the Mammoth Cave system? It is very possible. That cave system covers hundreds of miles in all directions. I have a cave across the street from my house. The bats come out in the summertime at night and buzz the house collecting insects. They are fun to watch. 4 Share this post Link to post Share on other sites
The Tuul Crib 7,336 #10 Posted March 12, 2021 OK here's a still picture maybe this will work for now. 2 Share this post Link to post Share on other sites
ebinmaine 67,309 #11 Posted March 12, 2021 That looks like an old Cart Road culvert from this angle. What's beyond the hole in the side of the hill? Share this post Link to post Share on other sites
The Tuul Crib 7,336 #12 Posted March 12, 2021 That is a 60 foot drainage tube I buried when I built my house. It's to divert this water away from my house. The wet weather spring is above that tube. Share this post Link to post Share on other sites
The Tuul Crib 7,336 #13 Posted March 12, 2021 Here is the wet weather spring above it. 1 Share this post Link to post Share on other sites
ebinmaine 67,309 #14 Posted March 12, 2021 We've got several locations like that on our mountainside property as well. We have one stream that runs pretty near all year that sprouts up out of the ground and runs maybe 100 to 200 ft then goes back under for about the same, comes up again and stays above ground at that point. 2 Share this post Link to post Share on other sites
953 nut 55,099 #15 Posted March 12, 2021 Had a wet weather spring where I built my shop. We had the track-hoe dig a pit at what seemed to be the wettest point and a four foot deep trench away from it and filled them with 1 1/2"-2" crushed stone. That moved the spring away from the shop about fifty feet. Works like a charm. 3 Share this post Link to post Share on other sites
tom2p 2,394 #16 Posted March 13, 2021 artesian well ? natural spring ? Share this post Link to post Share on other sites
