DennisThornton 4,769 #26 Posted March 6, 2021 46 minutes ago, Motorhead99999 said: Ok thank you. Had a brain fart... Meant "Supporter". My bad. Share this post Link to post Share on other sites
Motorhead99999 2 #27 Posted March 7, 2021 No other input on this guys. Share this post Link to post Share on other sites
bc.gold 3,403 #28 Posted March 7, 2021 14 minutes ago, Motorhead99999 said: No other input on this guys. Have you changed the filter. Share this post Link to post Share on other sites
pfrederi 17,866 #29 Posted March 7, 2021 (edited) The clicking noise sounds fairly normal it is the limited slip differential working. Did you look at the diagnostics in the manual?? Can you push it with tow valve closed.? Is the motion control plastic plate moving the control arm on the pump fully?? Edited March 7, 2021 by pfrederi 1 Share this post Link to post Share on other sites
squonk 41,321 #30 Posted March 7, 2021 The whining sound to me is an indication that all linkages and keyways are fine. It's the hydro struggling to move the tractor. May be time to find another trans. Years ago my C-160 would out of the blue start whining and bucking all over the place and erracticly. After checking the springs I replaced the hydro motor. It's starting to get a bit tired now. I have a complete unit in the shed ready to install when the day comes. 1 Share this post Link to post Share on other sites
Motorhead99999 2 #31 Posted March 7, 2021 On 3/5/2021 at 7:36 PM, pfrederi said: Why did you do that??? You should download the sunstrand manual from the manual section here. Has a good diagnostic section. 8 hours ago, bcgold said: Have you changed the filter. Yes I did Share this post Link to post Share on other sites
Motorhead99999 2 #32 Posted March 7, 2021 6 hours ago, squonk said: The whining sound to me is an indication that all linkages and keyways are fine. It's the hydro struggling to move the tractor. May be time to find another trans. Years ago my C-160 would out of the blue start whining and bucking all over the place and erracticly. After checking the springs I replaced the hydro motor. It's starting to get a bit tired now. I have a complete unit in the shed ready to install when the day comes. That’s what I was afraid of. So should I change the pump or motor. Or both Share this post Link to post Share on other sites
squonk 41,321 #33 Posted March 7, 2021 3 minutes ago, Motorhead99999 said: That’s what I was afraid of. So should I change the pump or motor. Or both Get a complete unit. If the Big show in PA happens in June there will be some available. There is a guy in PA on FB that advertises them if yo need one sooner and don't mind driving. PM me if you want details Share this post Link to post Share on other sites
Motorhead99999 2 #34 Posted March 7, 2021 13 minutes ago, squonk said: Get a complete unit. If the Big show in PA happens in June there will be some available. There is a guy in PA on FB that advertises them if yo need one sooner and don't mind driving. PM me if you want details Do you know what they run price wise. I found a complete tractor that runs but burns a little oil for $100. No implements. But he says it moves good. He’s a friend of mine so I doubt he would sell it to me knowing what I need if it wasn’t any good. 1 Share this post Link to post Share on other sites
pfrederi 17,866 #35 Posted March 7, 2021 Can you push it with the tow valve closed?? Share this post Link to post Share on other sites
squonk 41,321 #36 Posted March 7, 2021 15 minutes ago, Motorhead99999 said: Do you know what they run price wise. I found a complete tractor that runs but burns a little oil for $100. No implements. But he says it moves good. He’s a friend of mine so I doubt he would sell it to me knowing what I need if it wasn’t any good. That's the best way. A transmission plus parts Share this post Link to post Share on other sites
953 nut 55,767 #37 Posted March 8, 2021 On 3/5/2021 at 7:31 PM, Motorhead99999 said: So 20 years or more of child and early teen abuse The Sundstrand has "Acceleration Valves" which use spring pressure to regulate the fluid flow and speed/direction changes. Over time these springs give out and the fluid pressure will fight itself and the tractor won't move well or not at all. Take a look at the Sundstrand manual. https://www.wheelhorseforum.com/files/file/24-transmission-hydro-sundstrand-sm-492-4206pdf/ Share this post Link to post Share on other sites
953 nut 55,767 #38 Posted March 8, 2021 1 hour ago, Motorhead99999 said: Do you know what they run price wise. I found a complete tractor that runs but burns a little oil for $100. No implements. But he says it moves good. He’s a friend of mine so I doubt he would sell it to me knowing what I need if it wasn’t any good. Sounds like a plan. What model/year is your friend's ? Share this post Link to post Share on other sites
