Motorhead99999
Charger 12 automatic barely moves
DennisThornton
46 minutes ago, Motorhead99999 said:
Ok thank you.
Had a brain fart...  Meant "Supporter".  My bad.
Motorhead99999
No other input on this guys.
bc.gold
Have you changed the filter.
pfrederi
The clicking noise sounds fairly normal it is the limited slip differential working.  Did you look at the diagnostics in the manual??  Can you push it with tow valve closed.?
Is the motion control plastic plate moving the control arm on the pump fully??
Edited by pfrederi
squonk
The whining sound to me is an indication that all linkages and keyways are fine. It's the hydro struggling to move the tractor. May be time to find another trans.
Years ago my C-160 would out of the blue start whining and bucking all over the place and erracticly. After checking the springs I replaced the hydro motor. It's starting to get a bit tired now. I have a complete unit in the shed ready to install when the day comes.
Motorhead99999
On 3/5/2021 at 7:36 PM, pfrederi said:
Why did you do that???
You should download the sunstrand manual from the manual section here.  Has a good diagnostic section.
Yes I did
Motorhead99999
That’s what I was afraid of. So should I change the pump or motor. Or both
squonk
Get a complete unit. If the Big show in PA happens in June there will be some available. There is a guy in PA on FB that advertises them if yo need one sooner and don't mind driving. PM me if you want details
Motorhead99999
Do you know what they run price wise.  I found a complete tractor that runs but burns a little oil for $100. No implements. But he says it moves good. He’s a friend of mine so I doubt he would sell it to me knowing what I need if it wasn’t any good.
pfrederi
Can you push it with the tow valve closed??
squonk
That's the best way. A transmission plus parts
953 nut
On 3/5/2021 at 7:31 PM, Motorhead99999 said:
So 20 years or more of child and early teen abuse
The Sundstrand has "Acceleration Valves" which use spring pressure to regulate the fluid flow and speed/direction changes. Over time these springs give out and the fluid pressure will fight itself and the tractor won't move well or not at all.
Take a look at the Sundstrand manual.
https://www.wheelhorseforum.com/files/file/24-transmission-hydro-sundstrand-sm-492-4206pdf/
953 nut
Sounds like a plan. What model/year is your friend's :wh:?
